Is single photon monochromatic or not?
  • Thread starter fxdung
  • Tags
    Photon
In summary, a single photon need not be monochromatic in the same way as an electron need not have a fixed energy. A coherent state is a superposition of states with different numbers of photons so that the uncertainty of electric and magnetic fields is minimal.
fxdung
388
23
Must single photon be monochromatic or not must?What is coherence state?(in general and in optics),Does a quantum of field have ''single'' frequence(''monochromatic'') or multi-frequence?I know that because quantum mechanics particle ''lies'' in wave packet,so it has multi-frequence due to Heizenberg relation.
A single photon need not be monochromatic in the same way as an electron need not have a fixed energy. A coherent state is a superposition of states with different numbers of photons so that the uncertainty of electric and magnetic fields is minimal. There are no corresponding states for an electron, as there exists a super selection rule for the electron number (but not for photon number).
What is super selection rule for electrons?
There can't be superpositions between states containing different number of electrons. This is easiest to see for states differing by one electron. As the electron is a fermion, any matrix element ##\left n| V | n+1\right must vanish, as it gets multiplied by -1 upon a rotation by 360 degrees (i.e. the identity) as the electron is a fermion.
Why is coherence state when the number of photons tend to infinite?
There are many types of single photons. Some types are "monochromatic" and other types are not.
The uncertainty relation in the case of electron wavepacket is between position and momentum. Localized electron wavefunction in free space is supposed to be realized by introducing uncertainty in momentum, I guess it is this momentum spread which you referred to as "multi-frequency".
I think your English skill obscures your intention about what you actually wanted to say. The state of a quantum system is something one can control, for the states of photon, it can be number state, coherent state, squeezed state, etc. It's not like when the (expectation value of) number of photons increases, the state of light becomes more and more coherent. You can have number states with arbitrarily larrge number of photons, yet the electric field corresponding to such state is not coherent at all.
However, for the special case of coherent state, the observed electric field does exhibit certain dependency between the coherency, which may be defined as the uncertainty in phase at a given time, and the expected number of photons ##\langle \hat{n} \rangle##. For sufficiently large value of ##\langle \hat{n} \rangle##, the uncertainty in the phase of the electric field turns out to have the form ##\Delta \phi = 1/(2\sqrt{\langle \hat{n} \rangle})##. Therefore, if the number of photons is very large, the electric field becomes more and more coherent (i.e. it gets closer to being a classical field oscillation), in the sense that its phase becomes more definite.
I do not understand the average electromagnetic field of single photon is zero if we consider photon corresponding to electromagnetic field packet.Is it correct that the average value of electric field is<number photons/operator of the field/number of photons>?
Yes, correct, and the operator if the field is non-diagonal in particle number, hence it's expectation value vanishes.
Yes, that's the right expression. Now express the field operator in terms of the lowering and raising operators (similar to those in harmonic oscillator) and also remember that ##|\textrm{number of photons}\rangle## behaves exactly like the eigenstates of harmonic oscillator.
So there are two types of oscillation phase: one is classical phase of field that has raise and lower operator as amplitude of Fourier component of field; the other is oscillation phase of quantum of field(phase of wave function of the particle?).
Another question is if we interpret quantum of field as a packet of field why we know quantum of field is a point size particle or we have an axiom about the dual: particle- wave or particle-field.
Is there a uncertainty relation between position and momentum for zero mass particle?
FAQ: Is single photon monochromatic or not?
Is a single photon considered monochromatic?
Yes, a single photon is considered monochromatic because it has a single wavelength and therefore a single color. Monochromatic means having a single color or wavelength.
How is a single photon different from a wave of light?
A single photon is a discrete particle of light, while a wave of light is a continuous flow of energy. A single photon has a specific wavelength and energy level, while a wave of light has a range of wavelengths and energy levels.
Can a single photon have multiple colors?
No, a single photon has only one color because it has a single wavelength. The color of a photon is determined by its wavelength, and a single photon can only have one specific wavelength.
Is a single photon always visible to the human eye?
No, a single photon is not always visible to the human eye because it has a very small energy level, which means it does not produce enough stimulation in the retina to create a visual sensation. However, a large number of single photons can be seen as a beam of light.
Can a single photon be created or destroyed?
Yes, a single photon can be created or destroyed through certain processes such as emission or absorption by an atom or molecule. However, the total number of photons in the universe remains constant due to the law of conservation of energy.
