Is Space Expansion 100% proven?
In summary, there is some tension between FRW models and observations, and a stationary cosmology is going to have a hard time dreaming up the CMB and BBN.
waterfall
381
In a counterpart of General Relatlvity called Field Theory of Gravitation where spacetime is really flat and spin-2 fields cause gravity. See:
http://arxiv.org/pdf/gr-qc/9912003v1.pdf
Space is already there as the following description state:
"Cosmology is another field of application of gravitation theory. Present data about large scale galaxies distribution contradict to the main point of Friedmann cosmology — its homogeneity. It turned out that galaxies form a fractal structure with dimension close to 2 at least up to the distance scales bout 200 Mpc. This leads to a new possibilities in cosmology (see an analysis of FTG cosmological applications in the review of Baryshev et al., 1994). One of the main difference between FTG and GR is that the field approach allows the existence of the infinite stationary matter distribution (Baryshev, Kovalevskij, 1990). In a stationary fractal distribution the observed redshift has gravitational and Doppler nature and is not connected with space expansion as in Friedmann model."
Is there a possibility the above is the case and space didn't really expand but as I interpretated from the above.. space is already there? Or is space expansion 100% proven already beyond the shadow of a doubt? Thanks.
Space news on Phys.org
Wow. I'm amazed how wrong the 2nd sentence in the abstract is. The FRW cosmology describes a homogeneous universe. Is our universe homogeneous? That depends on the scale: on the scale of stars and galaxies, it is far from homogeneous. However, on the scale of the observable universe, owing precisely to the "fractal" nature of galaxy distribution, the universe is well-described by the FRW cosmology.
A stationary cosmology is going to have a hard time dreaming up the CMB and BBN.
First of all, physics does not "prove things 100%", so the answer to your topic is no.
Actually there has been some legitimate research done in this area, and there is some tension between FRW models and observations, see for example http://arxiv.org/abs/arXiv:0805.1132. I do agree with you that the sentence is ridiculous, but on a scale of wrongness, it could be more wrong :-)
and BAO, and fitting all of them together.
Related to Is Space Expansion 100% proven?
1. Is there concrete evidence that proves the expansion of space?
Yes, there is strong evidence that supports the concept of space expansion. This evidence comes from observations of the universe, such as the redshift of light from distant galaxies and the cosmic microwave background radiation. These observations show that the space between galaxies is expanding, providing evidence for the theory of space expansion.
2. Can we measure the rate of space expansion?
Yes, scientists have been able to measure the rate of expansion of space using a variety of methods, including observations of distant supernovae and the cosmic microwave background radiation. This rate is known as the Hubble constant and is currently estimated to be around 70 kilometers per second per megaparsec.
3. Is space expansion a proven fact or a theory?
Space expansion is considered to be a proven fact within the scientific community. While there are still some aspects of the theory that are not fully understood, the evidence for space expansion is overwhelming and has been confirmed by numerous observations and experiments.
4. Could space expansion eventually lead to the end of the universe?
There are several theories about the ultimate fate of the universe, but it is possible that space expansion could play a role in this. Some scientists believe that the expansion of space will continue to accelerate, eventually leading to a "big rip" where the fabric of space itself is torn apart. However, this is still a hypothetical scenario and more research is needed to fully understand the fate of the universe.
5. Is there any evidence that contradicts the theory of space expansion?
While there is a vast amount of evidence supporting the theory of space expansion, there are still some unanswered questions and potential limitations to the theory. For example, the exact cause of the acceleration of space expansion is still not fully understood and there are some discrepancies in the measurements of the Hubble constant. However, these challenges do not necessarily contradict the theory and are areas of ongoing research and debate in the scientific community.
  • Cosmology
