Is Special Relativity Testable?
In summary, the basic premise of special relativity is that absolute motion is not detectable. It can be tested through experiments involving mechanical objects and light rays. The prediction in the one-way light speed case is invariance, meaning that all inertial observers must obtain the exact value c when using two clocks to measure the one-way speed of light. However, this does not happen in the case of slow clock transport, and only the case of two always-mutually-at-rest clocks is applicable. The question of how SR can be tested in this case remains, as the one-way speed of light is defined to be c and cannot be tested independently. Despite this, SR is eminently testable through various experiments, not just involving
dbkooper
The basic premise of special relativity is that absolute motion is not detectable. Experimentally, this involves only two general cases, (i) detection via mechanical objects and (ii) detection involving light rays. Case ii readily resolves into two sub-cases, ii-a, detection involving round-trip light rays, and ii-b, detection involving one-way rays.Since cases (i) and (ii-a) were experimentally closed prior to special relativity (SR), this left only case ii-b for SR to actively pertain to.SR's prediction in the one-way light speed case is invariance.Specifically, SR predicts that all inertial observers must obtain the exact value c, and only that value, when using two clocks to measure the one-way speed of light. Since this does not happen in the case of slow clock transport, we can immediately eliminate that case. This leaves only the case of two always-mutually-at-rest clocks (in any given inertial frame).This raises the important question, How can SR be tested in that case? That is, how can an inertial observer use two clocks to experimentally measure light's one-way speed?
What is it that doesn't happen?
That is only one among many premises. As has been said already, SR is easily testable.
dbkooper said:
The basic premise of special relativity is that absolute motion is not detectable. [..]
Not exactly, and those things are related. The one-way speed is made equal to the two-way speed by means of clock synchronization - no "absolute" or "true" synchronization can be measured. The two-way speed is predicted to be invariant between inertial frames.
[..] This raises the important question, How can SR be tested in that case? That is, how can an inertial observer use two clocks to experimentally measure light's one-way speed?
That is not very useful, except to test for consistency or anomalities. Typically SR can be tested by verifying the two-way speed (and many other tests, see the FAQ).
Compare also this discussion: http://en.wikipedia.org/wiki/One-way_speed_of_light
Of course, SR predictions are numerous and can be tested/checked in many ways. It isn't some esoteric theory like string theory
DaleSpam said:
Special relativity is eminently testable:
http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html
Your restriction to tests of the one way speed of light is entirely artificial. Furthermore, the one way speed of light is c by definition. It isn't something which can be tested independently and it can simply be defined to be true.
The one-way case is the only open case because we have Einstein's word that it could "go positive" given absolutely synchronous clocks. He wrote, "The velocity of propagation of a ray of light relative to the carriage thus comes out smaller than c." (This observer used the clocks of classical physics to measure the speed of a departing ray of light.) http://www.bartleby.com/173/7.html
(FYI: It is untrue that Einstein's two results conflicted with the principle of relativity because these were *not* two different general laws as he claimed, but simply two specific instances of the *same* law, namely, c±v. But even this matters not; all that really matters is the fact that absolutely synchronous clocks will not get invariance for the one-way speed of light. What does this say about "simply defining invariance to be true"?)
What does not happen is that no form of clock transport (slow, very slow, very, very slow, etc.) results in exactly c. Indeed, each form of transport results in a different value!
The one way case is not open. Einstein's synchronization convention ensures that the one way speed is c, by definition. It is not a matter of experiment, just a definition of what it means for two clocks to be synchronized.
Anyway, the question has been answered. Yes, SR is testable. The thread is closed.
Related to Is Special Relativity Testable?
1. How is special relativity tested?
Special relativity is tested through experiments and observations that measure the effects of time dilation and length contraction, which are key principles of the theory. Some examples of these experiments include the famous Michelson-Morley experiment and the Hafele-Keating experiment.
2. What evidence supports special relativity?
There are several pieces of evidence that support special relativity, including the results of the aforementioned experiments, as well as astronomical observations such as the speed of light being constant in all inertial frames of reference and the gravitational lensing effect. Additionally, special relativity has been consistently and accurately used in many practical applications, such as GPS technology.
3. How does special relativity differ from classical mechanics?
Special relativity differs from classical mechanics in several ways. One of the key differences is that special relativity takes into account the concept of spacetime, where space and time are intertwined and can be distorted by mass and energy. Additionally, special relativity predicts that the laws of physics are the same for all observers in uniform motion, whereas classical mechanics assumes an absolute frame of reference.
4. Can special relativity be proven wrong?
While special relativity has been extensively tested and has yet to be proven wrong, it is always possible that new evidence or experiments could emerge that challenge the theory. However, it is important to note that special relativity has been incredibly successful in predicting and explaining various phenomena, and any new evidence would have to be extremely compelling to overthrow the theory.
5. What would happen if special relativity were proven wrong?
If special relativity were proven wrong, it would mean that our current understanding of the universe is incomplete and would require a new theory to explain the phenomena that special relativity currently accounts for. It is also possible that any new theory would still incorporate some of the principles of special relativity, as it has been a fundamental part of physics for over a century.
