Is switching to a Dvorak keyboard configuration worth the time and effort?
  • Calculators
  • Thread starter niehls
  • Tags
    Calculators
In summary, the HP49G+ is much faster than the HP calculators, but it is not as fast as the TI-89 Titanium. The HP49G+ also has more capabilities than the TI-89 Titanium, such as expandability and running Linux. The HP49G+ is cheaper than the TI-89 Titanium, but the TI-89 Titanium comes with a better processor.
  • #36
franznietzsche said:
if you had told me those keystrokes, even knowing what RPN is, i would i have no idea what you just plugged in.
# represents a number (ie key in a number, in this case the each # is a different component of the coordinates.
(enter) = hit the enter key
# the next coordinate
- = hit the minus key (this gives the difference of the 2 #s)
(enter) push the result onto the stack
* = hit the multiply key (compute the square)
# (key in another coordinate)
Enter
- compute the difference
Enter
* (compute the square)
Add em up
(Sqrt) yields the distance.
To use RPN you have to understand the stack, the modern calcs show several levels of the stack on the screen and the only limitation is calculator memory, this is very helpful. Back in the old days (I started with a HP35 in 1973) you only saw the x register and had to keep track of the stack (only 4 levels) for yourself. That can be tricky.
A neat trick for evaluating polynomials on any calculator is attributed to someone called Hooker.
Basicly you factor the polynomial eg,
[tex] x^2 + 3x +5 = x(x+3)+5 [/tex]
To evaluate this at x = 4
key:
enter
enter
Can you do it in fewer key strokes on your TI?
Computer science news on Phys.org
  • #37
Enter
Enter
Add em up
key:
enter
enter
I read those key strokes, know what the symbols mean, and i cannot possibly get them to make that equation.
I'm just going to stick to algebraic notation. Faster or not, i can read it and understand it much faster.
I get the feeling that RPN is somewhat like Perl: Really easy to use, hard to learn, and so short hand that it can be very difficult to read sometimes.
  • #38
That is pretty much correct, it is not for display it is for calculating. When all that matters is that you get the correct number. Every time I pick up a TI am having to get pencil and paper to write down intermediate results, With RPN I just push them onto the stack. I have never really learned to use a calculator with parens. Like you I just don't care to switch. Same reason I still use a QWERTY keyboard.
Now a days I rarly use a handheld, I just pop open Excel, but most of my computing is done near a computer.
  • #39
doesn't work like that on the 89. You just push the up button, highlight the result you want and press enter to insert it wherever your cursor last was. And you can pick from up to the last 99 results.
Its also very easy if you make a mistake entering to tell exactly what it is. to fix it, you just cycle up through entries (entries and results are in the same list, alternating so you get entry1, one the right of the screen at the bottom, answer 1 to the left of it, entry 2 right above... You just cycle up, select then entry, press enter, fix the syntax and hit enter gain to recalculate.
And I've never even seen anything other than a QWERTY keyboard. (well, the split keyboards, but those are still QWERTY, and i don't like them because of the way i type). I've heard of a Dvorak keyboard, but never seen one.
  • #40
You can flip a software switch and turn your keyboard into a Dvorak configuration... If you don't move the key caps to match, it makes a great way to protect your computer from non knowing users.. :biggrin: better then any pass word! The beauty of the Dvorak is that it was designed for effecient keying. While the QWERTY was designed to slow you down.
BUT... you have to learn to type all over again!
  • #41
i type plenty fast(faster than i can forumlate my sentences in my head) on a qwerty, in the dark, with my eyes closed, with no increase in typos, changing would then take me another 10 years to get as good at it. Absolutely no reason to change.
12K
61K
10K
63K
