Is t Algebraic Over F(S) in Field Extension E/F?
  • MHB
  • Thread starter mathmari
In summary, the conversation discusses the concept of algebraic independence in a field extension. It is established that if a subset $S$ is algebraically independent over $F$, then the subset $S\cup\{t\}$ is also algebraically independent over $F$, for any element $t$ in the extension $E$. The participants then discuss how to show that $t$ is algebraic over $F(S)$, and provide different approaches for proving this statement. There are also some clarifications and corrections made regarding the definitions and terminology used.
mathmari
MHB
5,049
Hey! :eek:
We have field extension $E/F$. We have that $S\subseteq E$ is algebraically independent over $F$. Let $t\in E$, then $S\cup \{t\}$ is algebraically independent over $F$.
I want to show that $t$ is algebraic over $F(S)$. Since $S\subseteq E$ is algebraically independent over $F$ we have that there exist $s_1, \ldots s_n\in S$ (different from each other) and non-zero $f\in F[x_1, \ldots , x_n]$ such that $f(s_1, \ldots , s_n)\neq 0$.
Since $S\cup \{t\}$ is algebraically independent over $F$ we have that there exist $s_1, \ldots s_n, t\in S\cup \{t\}$ (different from each other) and non-zero $g\in F[x_1, \ldots , x_n, y]$ such that $g(s_1, \ldots , s_n, t)=0$.
To show that $t$ is algebraic over $F(S)$, we have to show that there exist $s_1, \ldots , s_n\in S$ and non-zero $h\in F[x_1, \ldots , x_n]$ such that $t=h(s_1, \ldots , s_n)$.
But how exactly can we show the existence of such a polynomial? (Wondering)
I tried now the following:
We collect all the terms with the same powers of $y$ and then we can write the polynomial as follows:
$$g(x_1, \ldots , x_n, y)=b_0+b_1y+\ldots b_m y^m$$ where $b_i\in F[x_1, \ldots , x_n]$.
Since $g$ is a non-zero polynomial we have that for exampe $b_m$ is non-zero. It cannot be that $b_0\neq 0$ and $b_i=0, i=1, \ldots , m$ because then we would have the polynomial $g(x_1, \ldots , x_n)$ such that $g(s_1, \ldots , s_n)=0$, and that contradicts to the fact that $S$ is algebraically independent over $F$, right? (Wondering) Form the definition that $S\subseteq E$ is algebraically independent over $F$ do we have that for every non-zeropolynomial $h\in F[x_1, \ldots , x_n]$ there exist $s_1, \ldots s_n\in S$ (different from each other) such that $h(s_1, \ldots , s_n)\neq 0$ ? (Wondering) If yes, then it would hold for the non-zero polynomial $b_m\in F[x_1, \ldots , x_n]$, so $b_m(s_1, \ldots , s_n)\neq 0$. Then we would have the following $$g(s_1, \ldots , s_n, t)=0 \Rightarrow b_0(s_1, \ldots , s_n)+b_1(s_1, \ldots , s_n)t+\ldots b_m(s_1, \ldots , s_n) t^m=0$$
Therefore, we have a non-zero polynomial, where $t$ is a root.
Do we conclude from that that $t$ is algebraic over $F(S)$? (Wondering)
I thought about it again...
Since $S\cup \{t\}$ is algebraically independent over $F$ we have that there exist $s_1, \ldots s_n\in S$ (different from each other) and a non-zero polynomial $g\in F[x_1, \ldots , x_n, y]$ such that $g(s_1, \ldots , s_n, t)=0$.
It cannot be that $b_i=0, i=1, \ldots , m$ because then we would have the polynomial $g(x_1, \ldots , x_n)$ such that $g(s_1, \ldots , s_n)=0$, and that contradicts to the fact that $S$ is algebraically independent over $F$, right?
So, we have that $b_i\neq 0$, for at least one $i\in \{1, \ldots , m\}$.
Then $t$ is a root of a non-zero polynomial of $F(S)$.
Therefore, $t$ is algebraic over $F(S)$. Is everything correct? (Wondering)
mathmari said:
Hey! :eek:
Do you mean that "Let $t\in E$, and $S\cup\{t\}$ be algebraically dependent over $F$?"
What you infer is right but this is much weaker than what algeraic independence means.
Again, it seems you want to say that $S\cup\{t\}$ is algebraically dependent over $F$.
Yes, you are right! (Blush)
Is my idea of #3 correct? (Wondering)
What do you mean? (Wondering)
You are certainly on the right track. But thee again, you seem to have typos. You write "algebraically independent" when your intention seems to be "algebraically dependent".
Here is what I mean. Given an extension $E:F$, and a subset $S$ of $E$, we say that $S$ is algebraically independent over $F$ to mean the following: For any finite subset $\{s_1, \ldots, s_n\}$ of $S$, and any polynomial $f(x_1, \ldots, x_n)$ over $F$, if $f(s_1, \ldots, s_n)=0$, then $f=0$.
FAQ: Is t Algebraic Over F(S) in Field Extension E/F?
What does it mean for T to be algebraic over F(S)?
When we say that T is algebraic over F(S), it means that T is a root of a polynomial with coefficients in the field F(S). In other words, there exists a polynomial with coefficients in F(S) that, when evaluated at T, gives us a value of zero.
What is the difference between T being algebraic and T being transcendental over F(S)?
If T is algebraic over F(S), it means that there exists a polynomial with coefficients in F(S) that has T as a root. On the other hand, if T is transcendental over F(S), it means that there is no polynomial with coefficients in F(S) that has T as a root. In other words, T is not a solution to any polynomial equation with coefficients in F(S).
How can we determine if T is algebraic over F(S)?
To determine if T is algebraic over F(S), we can check if there exists a polynomial with coefficients in F(S) that has T as a root. This can be done by substituting T into the polynomial and checking if the resulting value is zero. If it is, then T is algebraic over F(S). If not, then T is transcendental over F(S).
What is the significance of T being algebraic over F(S)?
When T is algebraic over F(S), it means that T can be represented as a finite combination of elements in F(S). This allows us to perform algebraic operations on T using the elements in F(S). This property is important in many mathematical and scientific applications.
Can T be algebraic over F(S) if both T and S are transcendental over F?
Yes, it is possible for T to be algebraic over F(S) even if both T and S are transcendental over F. This is because the coefficients of the polynomial that has T as a root can still be elements of F(S), even if T and S are both transcendental over F.
