Is tan(x) continuous when x = pi/2?
  • Thread starter johann1301
  • Tags
    Continuous
In summary, the tangents function tan(x) is not continuous at x = 90 degrees or x = pi/2 because it is not defined at those points. This is true for all functions; if a function f(x) is not defined at a point x=a, then it is not continuous at that point. This is part of the definition of "continuous." There are different ways to define continuity, such as using epsilon-delta argumentation, but they are mostly equivalent. However, the precise consequences may vary, so it is a matter of personal preference. The theorem for continuity could be stated as f:U->R, where U is an open set, instead of referring directly to limit points. However, the function provided
johann1301
217
Is the tangents function tan(x) continuous when x = 90 degrees or x = pi/2?
Mathematics news on Phys.org
No, it isn't.
Likes 1 person
because it isn't defined at that point?
Correct. The domain of tan(x) doesn't include odd multiples of π/2.
is this true for all functions? If a function f(x) isn't defined at some point x=a, then f(x) isn't continuous at the point a?
Yes, if the function isn't defined at a point, then it's not continuous there. When we talk about continuity, we are necessarily talking about its domain of definition.
Likes 1 person
Thanks!
Do you not know the definition of "continuous" at a give point? It is
"A function, f, is continuous at x= a if and only if these three conditions are satisified:
1) f(a) exists (f is defined at x= a)
2) [itex]\lim_{x\to a} f(x)[/itex] exists
3) [itex]\lim_{x\to a} f(x)= f(a)[/itex]
Since (3) certainly implies that the left and right sides of the equation exist, often we just state (3) alone. But it is part of the definition of "continuous" that f is defined at x= a.
Ok, this makes sense, but what about epsilon and delta argumentation? Is that another definition?
Yes, you can define continuity in several different ways that are (mostly) equivalent. None of them has a function being continuous at a point in which it doesn't exist.
Likes 1 person
No. That's just used in the definition of a limit, which is used in the definition of a continuous function.
That's not necessarily correct, the Weierstrass definition can be used on its own without requiring you to define limits. But even if you define both they need not necessarily correspond, some authors will for instance define them slightly different and then give the "[itex]\lim_{x \to c} f(x) = f(c)[/itex] iff f continuous at c" as a theorem for limit points only (at least my analysis textbook did so). At the end of the day it doesn't make much difference of course, but it's still something to keep in mind.
As it turns out wikipedia (see article on "continuous function") falls for such an issue, probably due to using several different textbooks by different authors together. The Weierstrass definition has [itex]|x-p| < \delta[/itex], the definition for a limit has [itex]0 < |x-p| < \delta[/itex].
The difference is small but relevant, define [itex]f \subseteq \{ p \} \times \mathbb{R} = \{ (p, f(p)) \}[/itex]. Then the limit at p doesn't exist yet f is continuous at p.
Unless I misunderstand what you are saying, this is not an error. For a continuous function ##|x-c|<\delta## is used because the ##\epsilon##-##\delta## relationship must hold when ##x=c##. For a limit ##0<|x-c|<\delta## because the value of ##f(c)## is unimportant (not even required to exist).
If the limit doesn't exist, then there is some ##\epsilon>0## such that no corresponding ##\delta## can be found. If this is the case, it will still be the case when the restriction that ##0<|x-c|## is included. Of course ##\delta>0##. If not, then every point of a function would be continuous.
It is not an error by itself, but using these ways of defining it means that [itex]\lim_{x \to c} f(x) = f(c)[/itex] iff f continuous at c is not a theorem unless restricted to limit points.
The function provided above was intended as a counter-example. It is continuous since for all strictly positive [itex]\epsilon[/itex] there exists a strictly positive [itex]\delta[/itex] such that for all [itex]x \in \{ p \}[/itex] it is true that
[itex]|x - p| < \delta \Rightarrow |f(x) - f(p)| < \epsilon[/itex] which, since the only element of [itex]\{ p \}[/itex] is p itself boils down to
[itex]0 < \delta \Rightarrow 0 < \epsilon[/itex] which is true by definition of [itex]\epsilon, \delta[/itex].
That the function does not have a limit at p can be seen by that, as you say, it doesn't depend on f(p) but f(p) is all you have to base it on. Or more formally, no (non-empty) punctured neighbourhoods of p exist.
That's certainly correct. I wasn't paying enough attention. Thank you for pointing out my mistake.
The theorem could be stated as ##f:U\rightarrow\mathbb{R}## with ##U## open instead of referring directly to limit points (I think open sets would save the day).
You're welcome, but i wouldn't really call it a mistake. I was just trying to point out that the answer to the question whether they are different definitions is indeed yes, they are almost equivalent but not completely. In the end, as long as you're aware of the precise consequences, it's mostly personal preference as to how exactly you define continuity.
But is ##\{p\}## an open set? It seems impossible for it not to be. Are you thinking of an open interval (of real numbers)? Or are you thinking of some other larger space in which you consider ##\{ p \}## not to be an open set?
FAQ: Is tan(x) continuous when x = pi/2?
What is the definition of continuity?
The definition of continuity is a mathematical concept that describes the behavior of a function without any abrupt changes or gaps. A function is continuous if its output changes smoothly as its input changes.
How is continuity determined at a specific point?
Continuity at a specific point is determined by evaluating the limit of the function at that point. If the limit exists and is equal to the value of the function at that point, then the function is continuous at that point.
Is tan(x) continuous at x = pi/2?
No, tan(x) is not continuous at x = pi/2. This is because the tangent function has a vertical asymptote at x = pi/2, which means the limit of the function does not exist at that point. Therefore, tan(x) is not continuous at x = pi/2.
Can a function be continuous at some points and discontinuous at others?
Yes, a function can be continuous at some points and discontinuous at others. This is known as a piecewise continuous function, where different parts of the function have different continuity properties.
Are there any other values of x where tan(x) is not continuous?
Yes, tan(x) is not continuous at any value of x where the tangent function has a vertical asymptote. This includes values such as x = pi/2, 3pi/2, 5pi/2, etc. Additionally, tan(x) is also not continuous at any value of x where the function is undefined, such as x = pi/4 + n*pi, where n is an integer.
