Is that correct so far ... ?Yes, that is correct. Good job!
In summary: Lastly, we need to show that $x \in V$. Suppose $xeq 0$. Then there exists a number $a$ such that $x^3 + ax = a^3$, and similarly for all other numbers $x$. But this is obviously true for any number $x$, so $x$ must be in V.
Math Amateur
MHB
3,998
48
I am trying to gain an understanding of the basics of elementary algebraic geometry and am reading Dummit and Foote Chapter 15: Commutative Rings and Algebraic Geometry ...
At present I am focused on Section 15.1 Noetherian Rings and Affine Algebraic Sets ... ...
I need help to get started on Exercise 26 of Section 15.1 ...Exercise 26 of Section 15.1 reads as follows:
https://www.physicsforums.com/attachments/4764Help with this exercise will be much appreciated ...
Peter
***EDIT***
Thoughts so far are as follows:
I am assuming that when Dummit and Foote ask us to show that \(\displaystyle \phi\) is a morphism that, given the context, they are referring to what they have defined as a morphism or polynomial map between two algebraic sets ... in which case we would have to be sure we were actually dealing with a map between algebraic sets ... now \(\displaystyle V\) is obviously by its definition, an algebraic set ... but ... how do we show that \(\displaystyle \mathbb{A}^1\) is an algebraic set ... ?If, however we assume that both \(\displaystyle V\) and \(\displaystyle \mathbb{A}^1\) are indeed algebraic sets then we have to show that:
\(\displaystyle \phi \ : \ \mathbb{A}^1 \rightarrow V\)
is a morphism or polynomial map of algebraic sets ... that is we have to show that there exists polynomials \(\displaystyle \phi_1, \phi_2, \phi_3\) such that:
\(\displaystyle \phi(a) = ( \phi_1 (a) , \phi_2 (a) , \phi_3 (a) )\)
But, this is obviously true with
\(\displaystyle \phi_1 (a) = a^3 \ , \ \phi_2 (a) = a^4 \ , \ \phi_3 (a) = a^5\) ...
But... not sure of how to show the surjectivity ... even with the hint ...
Further ... I need help to make a significant start on parts (b) and (c) ...Hope someone can help ... particularly with parts (b) and (c) ...
Peter
Let's go one step at a time.
Suppose $(0,y,z)$ is in the zero set.
Then $xz - y^2 = 0 \implies y^2 = 0 \implies y = 0$.
Similarly, $z^2 - x^2y = 0 \implies z^2 = 0 \implies z = 0$.
Thus either ALL of $x,y,z$ are $0$, or $x \neq 0$.
Now it is clear that $(x,y,z) = (t^3,t^4,t^5)$ is in the zero set, for any $t \in k$:
$xz - y^2 = t^3t^5 - (t^4)^2 = t^8 - t^8 = 0$
$yz - x^3 = t^4t^5 - (t^3)^3 = t^9 - t^9 = 0$
$z^2 - x^3y = (t^5)^2 - (t^3)^2t^4 = t^{10} - t^6t^4 = t^{10} - t^{10} = 0$.
So we see that $\{(t^3,t^4,t^5): t\in k\} \subseteq \mathcal{Z}$. The question becomes: is EVERY element of the zero set of that form?
Now if $(x,y,z) \neq 0$, we see that $x \neq 0$. Thus $x$ is a unit of $k$. Hence $y = ax$ for some $a \in k$ (namely $a = \dfrac{y}{x}$).
Then:
$xz - y^2 = 0 \iff xz - a^2x^2 = 0 \iff x(z - a^2x) = 0 \implies z - a^2x = 0$ (since $x \neq 0$).
So $(x,y,z) = (x,ax,a^2x)$.
Consequently, re-writing $yz - x^3 = 0$:
$ax(a^2x) - x^3 = 0 \implies a^3x^2 - x^3 = 0 \implies x^2(a^3 - x) = 0 \implies a^3 = x$
so $(x,y,z) = (a^3,a^4,a^5)$, or if you prefer: $(x,y,z)\neq 0 \in \mathcal{Z} \implies (x,y,z) = \left(\dfrac{x^3}{y^3},\dfrac{x^4}{y^4},\dfrac{x^5}{y^5}\right)$
Now the zero set point $(0,0,0)$ is clearly of the form: $(0^3,0^4,0^5)$, so this shows the zero set is contained in the image of $\phi$, so $\phi$ is surjective.
FAQ: Is that correct so far ... ?Yes, that is correct. Good job!
What is a morphism of algebraic sets?
A morphism of algebraic sets is a polynomial map that preserves the structure of algebraic sets. This means that the image of a closed subset under the morphism is also a closed subset.
How is a morphism different from a polynomial map?
A morphism is a special type of polynomial map that preserves the structure of algebraic sets, while a polynomial map is simply a function that can be expressed as a polynomial in the variables. This means that a polynomial map may not necessarily preserve the structure of algebraic sets.
What are the properties of a morphism of algebraic sets?
A morphism of algebraic sets has the following properties:
  • It preserves the structure of algebraic sets.
  • It maps closed subsets to closed subsets.
  • The inverse image of a closed subset is also a closed subset.
  • It respects the algebraic operations of addition and multiplication.
How do you determine if a polynomial map is a morphism of algebraic sets?
To determine if a polynomial map is a morphism of algebraic sets, you can check if it satisfies the properties listed in question 3. Additionally, you can also use the fact that a polynomial map is a morphism if and only if its coordinate functions are polynomials.
Can a morphism of algebraic sets have singular points?
Yes, a morphism of algebraic sets can have singular points. These are points where the Jacobian matrix of the coordinate functions is not full rank. However, the set of singular points is always a closed subset and the morphism maps this set to another closed subset.
