Is the backward extrapolation of the expansion of the Universe valid?
In summary, the universe is expanding, so at one point in the past it must have been all concentrated into a single point. But is this really an accurate observation?The universe is expanding, so at one point in the past it must have been all concentrated into a single point. But is this really an accurate observation? There is a concept of the scale factor, which allows for the expansion ring to generate enough space per year.
PhysicalAardvark
TL;DR Summary
Summary: The universe is expanding, so at one point in the past it must have been all concentrated into a single point. But is this really an accurate observation?
Hi,
This is my second probably naive question that's been on my mind as a lay-scientist for a long time (the other will hopefully appear as 'Dark energy noob question').
The reasoning behind the Big Bang seems to be as follows; The universe is expanding in all directions. So at some point in the past it must have been smaller. So at some point way, WAY back, it must have come together at a single point.
Now, this may be completely valid, but given that the remote galaxies we are talking about here are billions of light years distant, how accurately do we need to know that the are all accelerating exactly away from each other to ensure that they all came from a single point?
If all matter had originated in a volume rather than a point, wouldn't we still see exactly the same behaviour, to the levels of accuracy that we can measure?
Thanks,
P
Space news on Phys.org
You have a common lay misconception of the Big Bang being a form of explosion. This is not the case. The expansion is space itself expanding. The Big Bang occurred everywhere, it is just that ”everywhere” was smaller.
Likes Klystron and PhysicalAardvark
I did know this, but hadn't put two and two together in terms of the origins of the universe. So thanks for that; it makes a lot of sense.
So I'll re-phrase my question. Is there still the concept that at one point in time "everywhere" was infinitesimally small? And is this necessarily the only conclusion?
P
If the Universe is infinite now, it was also infinite during the big bang. Observable Universe was way smaller then now.
Touche.
I guess I still have this concept of everything being compressed, somehow. The 'Hot Big Bang', after all. Where there is too much energy in the space it occupies for the single particles we now know to even exist in that form. And then things 'spread out' and 'cool down' so that matter can condense. This is certainly the picture painted in most popular press I see.
But if there has always been infinite space, why were these transitional phases needed? And why is inflation needed to explain rapid expansion if the universe has always been infinite anyway?
Thanks for your answers, folks, I've already progressed my understanding more in an hour than I could have in months trying to study it for myself.
P
Back to a single point is an overstatement. The universe was very small, but the origin is unclear.
Our models obviously break down at some point, but it's not clear where. It doesn't really make sense to have infinite density.
Even in an infinite universe it makes sense to talk about the scale factor - how distances change over time. While the mathematical volume is always "infinite" there is a real change in the universe over time.
It is possible (and usually expected) that the density was never really infinite, but that the universe started in some really compact version with an extremely high but finite density. How compact? We don't know. The Planck density would be a plausible number but it could be something else as well.
We do know that it expanded at least from the earliest point on where we know the laws of physics, because we can observe the results of this early expansion (e.g. in the ratio of hydrogen to helium to lithium any similar measurements).
I kind of have an oddball question about this. If the universe was expanding in the same amount every year, eventually the universe would be very misshapen. Because the amount of space being generated would not complete the next concentric circle of expansion. From what I have read, space expands, but the amount of actual matter remains roughly the same, and each concentric ring expands to the point where it has more space per mass, and thus a lower density per expansion ring on the outer edges.. If we are measuring these rings in individual years, what allows the expansion ring to generate enough space per year, when it has to push all of the existing space out to fill the inner most ring, but then also provide enough space for each additional ring to completely expand within a year? Every time the universe expands, it basically has to generate enough space to expand each previous year of space to fill a bigger concentric ring for the next year, plus the inner most ring, and push the outer most ring further out, and expand how much space IT contains. That's a HUGE amount of space generated per year, and it gets bigger each year. Aaaaaaand...it has to complete all of those expansions exactly within a year.. so, it has to generate much more space per year, and do in it faster to be able to fill the appropriate amount of void or space within that year. I guess my over all question is, if we assume the expansion of the universe is an autonomous process, then phyisically, doesn't it have to be designed to fulfill that process physically. Doesn't this technically mean that the universe has to be physically designed in such a way that this expansion could only work this way, or the whole thing would either not expand right or at all or hyperexpand, or expand unevenly?
Not if it is expanding at the same rate in all directions at every point, which it is (at least on average, which is how we model it).
I have no idea where you are getting this from, but it's wrong. The average density of the universe (on large enough scales so that our global model is a good approximation) is the same everywhere. The expansion is not a process of adding "rings"--the universe is not a volume with a boundary that is adding "more space" at the boundary.
Annd? Now that you've told me what its not, how about explaining what it is? I am always up for learning more about this..
Have you read the earlier posts in this thread? Particularly the ones by @Oroduin and @mfb.
What other sources have you looked at?
Concentric rings around what? There is no special place in the universe. There are no outer edges or inner regions either.
It wasn't, by any metric, but this doesn't matter here.
@MainFragger May I suggest that you take a gander at the linked article:
https://www.mso.anu.edu.au/~charley/papers/LineweaverDavisSciAm.pdf
This is a paper by Charles Lineweaver and Tamara Davis (two rather credible sources), entitled _Misconceptions About the Big Bang_. It was published as an article in Scientific American some years ago, and in my opinion, one of the most readable, yet fact laden and informative short pieces on the subject. Give it a read, and I predict you will spend the next hour or so half vocalizing "wow... hmmmm... I never really... but wait, so that's how..."
Its a fun read. Check it out.
And for extra credit, do a little search engine research on the origin of the _term_ 'Big Bang'.
diogenesNY
I have read that article, and it doesn't really change what I was asking. Sorry it took me a while to get to it it, I do contract work, and that keeps me moving around and busy a lot. The point is, at some point or other the universe started out as something really small, and is growing and growing at an exponential rate. Its not a perfect 3D orb, but close enough for the purpose of general description of my question. There are no physical concentric lines laid out in the universe, in the same way that there is no physical lines between Pennsylvania and New Jersey, New York, Delaware, West Virginia, and Ohio. Which is to say, yes, there's not a physical line, but if we wanted to map something out, we imagine the lines. The universe is predicted to be about 13.8 billion years old, so if you wanted to keep it simple, small and digestable, you could say that every billion years is a "ring" in the expansion of the universe (like rings in a tree). I like even numbers, so I am just going to round that off to 14 rings. At one point the universe was just what we would call the center...but then at some point it expanded enough that the the center became big enough to consider more than one part or ring. In this case, a billion years seems like a good place to start for a segment of our radius line, as well as however many light years that is in distance.
That having been said, my question is.. As the universe expands..if something were pushing it to expand, it would need a certain amount of pressure and perhaps matter at the center to keep pushing the segments in the center out to the next area/ring of expansion. If it used the same amount of pressure or mass as before, it would probably fall flat of completing that next ring in time for the next billion years. The simplest way to think of this is that each new area of space that has expanded has to actually be bigger than the area before it. If you used the same everything within that second billion years to achieve that, it wouldn't work, you'd get something that is mis-shapen and incomplete. So, whatever mechanism is causing the universe to expand, has to have enough energy to get the next ring exactly right..not too much, or it would be bigger, and not too little or it would be smaller and in both cases not properly formed.
So, what is the mechanism of expansion? Because if it isn't a living thing that can accommodate and adjust for inaccuracies, the consistently even growth of the universe points to a universe designed to keep its shape regardless of what happens next without any kind of thought process or intervention. Its is designed to keep its design and growth rate consistent without anyone's help.
My second question is related to the speed of the expansion of the universe. I have read that the closer to the further edges you get to the faster the galaxies are moving away. But, what I don't fully understand is, if the galaxy is moving away from you faster, and it is say 70% into the light year radius line of that area of the universe, when it expands to the next expansion ring, does it end up at the same 70% mark? Or does it shift a little. Also, When you say that the galaxies expand away from each other faster, is that because it reaches the edge of its billion year area faster? Or because it reached and surpassed its previous position from the previous ring faster? Because 70% of each ring that is further out is further than the previous 70 per cent, but also, may not line up perfectly with the radius line.. because it may be more important that it moves to 70 perceent of the space created in each new expansion vs. 70 percent of its straight trajectory.
No, it started out as something really dense and really hot. In our best current model, the universe is spatially infinite, so it wasn't "small" at any time.
It is now, but it wasn't until a few billion years ago. Before then the expansion was decelerating, not accelerating.
No. As @Orodruin already pointed out way back in post #2, this is not how the expansion of the universe works. The universe is not expanding into a pre-existing space, and there is no "center".
There isn't. The expansion is due to inertia: at the end of inflation, the universe was in a very hot, dense, rapidly expanding state, so it kept expanding by inertia.
Until a few billion years ago, the expansion decelerated because the gravity of the matter and radiation was slowing it down. Now the expansion is dominated by dark energy, which causes it to speed up. Those things affect the rate of expansion, but the universe would still be expanding anyway.
It hasn't been "consistently even". See above.
No, the farther you get from us the faster the galaxies are moving away relative to us. But that is only relative to us. There is no "edge".
Likes QuantumQuest
An oft-used example to look at how the universe expands is the "raisin bread" analogy.
Consider a spherical ball of raisin-filled dough in the oven. The raisins are essentially evenly distributed throughout the dough.
The dough expands equally, at every point. Any two adjacent raisins are moving away from each other at the same speed as any other two adjacent raisins.
Raisins that are far apart from each other move away from reach other faster.
In fact, the rate at which any two raisins move apart from each other is directly proportional to the distance between those two raisins.
Thus, even when the ball of dough is two or three times its original size, the raisins are still distributed evenly.
Likes pinball1970
What I don't like about the raisin bread analogy: It is a 3D space that is in the larger environment. The bread - unlike the universe - has a boundary. The balloon analogy avoids that.
Likes DaveC426913
Well, to some extent. It has different issues, such as the existence of a higher-dimensional embedding space.
Me too.
No; I get this now (as a result of asking this question).
The universe seems to have started everywhere, and all at once. All of that is expanding simultaneously.
I've paid very specific attention to 'modern' science documentaries on the topic; and they mostly agree with this.
Astonishingly, 'The Wonders of the Universe' with Brian Cox completely agrees with this idea. I'd listened to it a dozen or more times, yet somehow missed this crucial point. The universe did not start at a point. It started everywhere, and all of that is expanding.
But there are still mainstream science documentaries (Jim Al-khalili; looking at you) where it is explicitly stated that the universe started at an infinitesimal point.
I still have had no answers whatsoever about my more serious question, though.
Certainly. Which is why the analogy only goes so far. I really just wanted to address the OP's assumption that expansion occurs somehow heterogenously.
What "more serious question" has not been answered?
Well, you can remove the boundary. Imagine the bread is infinite in all directions at all times. Then, to help mental intuition, you may envision the expansion stepwise. You imagine the infinite bread as first broken into an infinite collection of finite loaves, double each one's volume, put them back together. Repeat. Somehow this was the first way I could succeed in picturing the expansion without running into mental obstacles like how do other pieces get out of the way fast enough. Then, over the balloon analogy, this has the advantage of being 3-d and never finite, rather than 2-d and always finite.
Likes DaveC426913
The rest of your questions seem to stem from your idea of these "expansion rings", which as you now know, is flawed.
So, in the wake of your updated idea of cosmological expansion, what further questions do you have?
I don't like it too, I'm missing in addition the free fall. Therefore I prefer the picture that the galaxies are just falling away from each other. :biggrin:
The balloon analogy also fails to capture the free fall in vacuum feature of mathematical model. In one case you are led to see dots carried by stretching plastic, in the other raisins carried by expanding dough. In reality, galaxies are, indeed, in free fall and are not carried by anything.
The closest analogy I know of to capture this is only 1 x 1 finite model. Imagine a cone pointed downward, missing its tip. The circles around it represent space, vertical axis is time. Then galaxies are following straight lines away from the missing tip. The straightness implies free fall, the collection of lines captures initial conditions, the geometry of the cone captures that there is simply enough room for the straight motion to continue. The expansion is then just a statement about the shape of the manifold and the initial conditions. But then you have to somehow imagine these features being true for more dimensions with spatial slices always infinite. I don’t know of any simple way to picture this.
Likes Ibix
On the other side this analogy seems a lot more abstract than the raisin bred analogy. Couldn't it be that if somebody understands and likes it he then would prefer to imagine the reality, the galaxies going further and further away from us?
As long as you can imagine this being similarly true for every galaxy being 'us', then that is fine. Also, that there is and never was any 'center', and that spatial extent is and always was infinite.
Note, that in my 1x1 analogy, the spatial slices are without boundary or center at all times, but finite. Any perceived center is in the embedding space, not the toy universe.
The first means the cosmological principle. But isn't the latter an assumption?
  • #31
Not an assumption, quite. It is a match of GR to observations, such that either observations have large errors we don’t know about, or GR is wrong at large scales.
  • #32
Yes, agreed, thanks. As far as I am aware of we have no indication suggesting that "GR is wrong at large scales" though.
  • #33
I am totally confused. I feel like I am in a converstion with Zathras.."He is the one! But he is not the one!"
As best as I can tell, you are saying that even before the universe as we knew it existed there was a void, but technically that void is the universe. And since the void is endless, the universe is endless and has no real border. At some point or other, SOMETHING at some random location in the void heated up really intensley and spewed out our universe (as we know it)...then it cooled down a bit, slowed down a bit, and then at some point sped up again. Wherever that occurred, matter must have been really dense. And All the galaxies are spreading out relative to each other, and as they spread out, the density of the universe gets redistributed. When the universe stops expanding..does that mean the density has equalized across the universe? I have more questions, but this seems like my major sticking point at the moment. And I know I keep getting pulled away from this for long periods of time..but with the quarantine on, I promise I'll try to keep an eye on this post and respond quickly..
  • #34
The density was and will be always equalized across the universe if you think of scales large enough.
Our observational data suggest, that our universe ("spewed out" in your terminology) consists of two kinds of ingredients, the dark energy (the cosmological constant resp.) which "works" gravitationally repelling and other stuff, matter and radiation which work gravitationally attractive. The density of the first is according to our model constant over time, the second gets thinned over time due to the expansion of the universe. At present our model says that our universe will expand for ever. This means that matter and radiation will be negligible far in the future.
  • #35
Um, no; I was very happy with the original responses, it was someone else who started the whole 'expansion rings' thing.
The only problem I now have about the big bang expansion is the oversimplification presented by the science media; and that's probably acceptable in the same way that 'the force of gravity' is still constantly referred to; sometimes even in the very same programs that are discussing General relativity!
The other question I was referring to was on this thread, and it seems that there now has been some traffic on that thread too. So I'll take up any further problems I have with it there.
Although a skim-read seems to indicate that I won't need to; you folk are pretty good at this stuff!
Cheers,
P
  • Cosmology
  • Cosmology
