Subhra said:My question is very simply: If a moving charged particle can create a magnetic field, can a charged particle move in a magnetic field?
Subhra said:I am sorry, I didn't understand you. Consider a charged particle at rest. Now place a bar magnet close to it. What will be the equation of motion of the particle due to the applied magnetic field?
Subhra said:I didn't even tried to understand the meaning of r. This probably implies that if there be a magnetic field at a point P1 and the charge at P2 such that P2-P1=r, the velocity of the charged particle will be v due to the field at P1.
Subhra said:Due to the cross product, there might not be any unique solution for the velocity of the charged particle. Yes, I agree to it. If this is so, there should be at least one non-zero value of the velocity.
I don't find any way to "invert" the Biot-Savart Law MATHEMATICALLY and that's why I didn't defend equation (2). I am just trying to find the causality relationship between the magnetic field and the motion of a charged particle. In this regard, Biot-Savart law tells us that if a charge particle moves, it will create a magnetic field and I wish to know whether the reverse is true or not i.e. can a magnetic field move a charged particle or not.
Subhra said:The point is misunderstood here. Let's have a magnet at point A. Now put a charge at point B near A. Now come to the question: Will the charge move?
Subhra said:If you consider Lorentz force Law, no force will act. Is it so if you consider Biot-Savart Law or in this case equation (2)?
Subhra said:So, according to you a charge at rest will remain at rest even if there be a magnetic field?
Subhra said:Please find the attachment and comment about equation (2).
Subhra said:The question is very simple. I repeat:
According to Biot-Savart Law if there be a charge in motion, it will create a magnetic field. (Look into Heaviside's electrodynamics to confirm the existence of this law for point charges). If the motion be uniform, the magnetic field will be static, else dynamic. The nature of the magnetic field is not important here.
Now, if a charge particle be placed in a magnetic field, will it move? To put it in another way, is the velocity of the charged particle dependent on the applied magnetic field?
Only if the uniform motion refers to motion of constant electric current in a circuit. If you mean uniform motion of one charged particle, its magnetic field will not be static. It will move along with the particle.Subhra said:If the motion be uniform, the magnetic field will be static, else dynamic.
Matterwave said:This question has been answered many times already. A static charge in a static magnetic field will not move.
Jano L. said:Only if the uniform motion refers to motion of constant electric current in a circuit. If you mean uniform motion of one charged particle, its magnetic field will not be static. It will move along with the particle.
Jano L. said:No, No. If the particle is put at rest into the applied magnetic field of other sources, it will not move, because the magnetic force vanishes.
Subhra said:According to Biot-Savart Law if there be a charge in motion, it will create a magnetic field.
Subhra said:Then tell me whether the magnetic field in Biot-Savart law is "static".
carrz said:Second charge will experience force only if it has velocity greater than zero.
Matterwave said:It is static. But this question doesn't have much to do with your previous question.
Subhra said:So a stationary charged particle will not experience any force near a current element.
