Is the "clack" sound from Newton's Cradle periodic?
In summary, the conversation revolves around whether the sound produced by Newton's Cradle is periodic. The participants discuss the definition of periodic and its relation to the motion of the cradle's balls. They also mention the role of friction and energy loss in determining the period, and whether the number of spheres in the cradle affects the sound's frequency. Ultimately, it is concluded that the sound is indeed periodic, with the period remaining constant regardless of the decreasing amplitude.
StevenJacobs990
They certainly do sound periodic from observation. But is there a particular formula that proves that sound from Newton's Cradle is periodic?
I think of periodic as a uniform period. Isn't it the case that with Newton's Cradle the period decreases very slowly but constantly as the balls to go less and less high and return more and more quickly?
Likes davenn
I would think not since each end is half a pendulum. That assumption and a zero transit time for the impulse is all it takes to show it is simple harmonic motion. And even woth the delay it would still be periodic.
I thought the small amount of energy lost as heat due to the impact would change that. I guess your assumption of zero transit time makes it an ideal case with no lost energy so we are describing slightly different things, yes?
No, zero transit time is different from lost energy. With zero transit time you get a decaying amplitude sine wave (the decaying amplitude is the lost energy, whether it is in the impact or in air resistance). Including the transit time just gives you a little pause each cycle. This is why pendulums make good clocks: period is independent of amplitude.
Likes davenn
And this is why we need to be a bit more advanced and talk about differential equations.
In simple words, the friction would make a function that multiplies the sinusoidal function. No term from the friction will be present inside the sin function itself.
What this means: The period does not change, only the amplitude as russ_watters said.
Thanks guys.
@StevenJacobs990, the thread got a bit derailed by my misunderstanding but the answer is yes its periodic. As to the exact equation with exact values, that will depend on the parameters of the pendulum.
But what proves that the sound is periodic? I'm not asking for the exact equation with exact values.
I want to know whether the period stays constant regardless of the decreasing amplitude (the height the ball on each end reaches, which decreases over time because of energy loss).
So I thought of this pendulum equation T = 2(pi)(sqrt of (L/g)). Does this prove that Newton's cradle is periodic even over time?
Because according to this equation, length of the string that holds the mass is the only thing that affects the period, not the amplitude.
Since Newton's cradle has a periodic motion, the sound must also come periodically. Every time the mass passes the lowest height it can get, you'd get the sound.
However the time period of the sound would actually be half of the pendulum's.
Would the period change depending upon the number of spheres in the cradle? I seem to hear 3 spheres in motion 'clanking' more frequently than when 5 are in motion?
... which is actually a function of the amplitude; not a strong function admittedly but still ...
russ_watters said:
period is independent ofn amplitude.
... , sorry Russ, but phinds was correct.
We actually had a lab on the subject and I measured it again in some videos of Newton's cradle. The frequency does not change, even if the masses were coupled in case of a symmetric motion (the two coupled masses move together in the same way).
This is why in physics we don't use "seem" to draw conclusions. We do however allow 'seem' to be used as a reason why we are testing something, to raise a question as you did. Once we test it with proper equipment, we sometimes see our intuition was wrong. We are awful at processing data beyond survival.
Edit: After some derivation using Newton's laws of motion I came to a conclusion that the masses should move together. Using this knowledge you can convert the mass into a mass twice bigger on a single string (or two parallel to one another so the mass would only move on one axis but for calculation we assume one) so the only effect you would have is in conservation of momentum.
The frequency does not change.
Likes Fervent Freyja
FAQ: Is the "clack" sound from Newton's Cradle periodic?
Yes, the "clack" sound from Newton's Cradle is periodic.
What causes the "clack" sound in Newton's Cradle?
The "clack" sound in Newton's Cradle is caused by the transfer of kinetic energy between the swinging metal balls.
Does the "clack" sound change as the number of balls in Newton's Cradle changes?
Yes, the "clack" sound may change as the number of balls in Newton's Cradle changes due to differences in mass and speed of the balls.
Can the "clack" sound in Newton's Cradle be used to measure time?
No, the "clack" sound in Newton's Cradle cannot be used to measure time accurately as it is affected by external factors such as air resistance.
Is the "clack" sound in Newton's Cradle affected by the length of the strings?
Yes, the length of the strings in Newton's Cradle can affect the "clack" sound as it changes the speed and trajectory of the swinging balls.
