Is the concept of "potential" just a mathematical model?
In summary: Because two obsevers of different complexity can not possibly, encode the same information. So there is bound to be both redundancies and losses as one compare models.
zb23
TL;DR Summary
potential
is the concept of potential just a mathematical model
No. Differences in potential are measurable.
yes of course
Of course you are correct, but I am in a disputative mood. The notion of an absolute potential is perhaps a mathematical construct ? Absolute velocity also? Perhaps the distinction is important...or is my head just burnt from the week.
Likes protonsarecool and dRic2
Well, it seems it has been that kind of a week in general
So, the question was is it "just" a mathematical construct. I think it is not "just" a mathematical construct, but as you point out, it does have a gauge symmetry. So that makes it a little weird. However, this gauge symmetry leads (per Noether's theorem) to a conserved quantity. In this case, charge. I cannot think of something more physical than a conserved and invariant quantity. And since that quantity directly implies a potential with the property you pointed out, I still tend to say that "just" mathematical is not an accurate description.
Likes dRic2 and zb23
Thank you. Most interesting.
Likes Nugatory and Dale
I don't like the word "just", except in the context of "it is just to help the less fortunate."
What does it mean to be "just a mathematical model"?
Is the electric field "just a mathematical model"?
Is electricity "just a mathematical model"?
Is gravity "just a mathematical model"?
Likes Dale, martinbn, zb23 and 2 others
The Aharonov-Bohm effect is hard to understand without assuming that the potential is somehow "real".
Likes protonsarecool, vanhees71, Dale and 2 others
Sounds like an idea from Zen and the Art of Motorcycle Maintenance
  • Haha
Likes vanhees71, Dale and Demystifier
Is it hard or is it impossible? If it is hard, then it still can be understood?
I would say impossible, but it's somewhat subjective because it depends on what one means by "understood".
Likes Fra
Well you have the choice to interpret the AB effect in a local way using the potentials or a "non-local" way using the em. field. Both interpretations are equivalent and lead to the same (most importantly gauge invariant!) predictions.
vanhees71, I am very intrigued by your statement on 13 January, 2021 that the: "..."non-local" way using the em. field." is equivalent to the local way via potentials in interpreting the AB effect. I was hoping you could point me to a reference for this "non-local" way of interpreting the AB effect, that goes into more detail.
@Davephaelon this thread has been inactive for 6 months. Notice the
"at-signMember" construct. You may want to use it ping another member in the context of a dormant thread. e.g., @vanhees71 will ping that member... that member is very good at answering inquiries.
A very good discussion of the AB effect can be found in
J. J. Sakurai, S. Tuan, Modern Quantum Mechanics, Revised Edition (1993)
Likes malawi_glenn
zb23 said:
Summary: potential
This type question can be asked about pretty much everything in physics. While it's obvious that all we talk about are models, it seems unreasonable to think that these models would be as successful if there wasn't any kind of relation between nature, and the abstractions (ie our models).
But as one refines the question, one may arrive to ask how large "mathematical redundancy" is there in our "models" as compare to the mechanism in nature I think the question itself requires choosing an observer. Because two obsevers of different complexity can not possibly, encode the same information. So there is bound to be both redundancies and losses as one compare models. Which is why it seems reasonable to think that various things like "potentials" are relative to the observer.
Would we label such observer dependence as "just a model"?
Another example, I suspect most will agree for example that the continuum which is the basis for system equation based dynamics in general are more a mathematical abstraction/model, which a doubtful relation to nature. So spacetime also is just a mathematical model? As spacetime is quite central to physics, all thing depending on it is also living with the same issues.
/Fredrik
Likes Dale
Thank you Jim McNamara, Vanhees71, and, Fra, for the responses. I'll check our local library for that book authored by J. J. Sakurai and S. Tuan. If it's not too expensive I'll purchase it.
/Fredrik
Electrodynamics is a gauge theory. The potentials ##\Phi## and ##\vec{A}## can thus not be interpreted as "observable fields". Directly observable are only gauge-independent quantities as the electromagnetic field, ##(vec{E},\vec{B})##, while this physical observation is described by a quotient space, i.e., an entire equivalence class of potentials, each different from each other by a gauge transformation with an arbitrary scalar field, i.e., ##\Phi'=\Phi+1/c \partial_t \chi## and ##\vec{A}'=\vec{A}-\vec{\nabla} \chi## describe the same physical situation.
I'm not sure, what you mean by "observer dependence". Of course the split of the electromagnetic field in electric and magnetic components is frame dependent but the physical laws are the same in any inertial frame of reference. In contradistinction this is a true symmetry, which gauge invariance is not.
Likes zb23
In quantum mechanics the potential is usually the object that enters wave equations. The electric field is hardly ever mentioned, except sometimes as a mathematical intermediary.
Of course. The more it is important to have a clear understanding of what's observable, i.e., how to interpret the results: Only gauge-independent quantities directly represent observables.
I just noticed that this thread wasn't in the interpretational subforum, so I will make a short comment not to diverge things.
My point was to elaborate one what "observation" means by embracing the whole inference process? Not just inferring a state, given the laws and structure.
In the standard formalism, the state space, the hamiltonians describing their time evolution are NOT formally treated as result of observations including postprocessing. [Which I think they should] In science they still are of course, as the history of science by abduction to best explanation has inferred these laws and these state spaces etc[that is the inconsistency]. But the process of inferred the laws, even relative to a given observer, is not treated as physics in the current paradigm, it is treated at "human science" level.
The the conventional notion of observable effectively is built from
- records from classical detector counts if distinguishable events
- acquired from repeats of similarly prepared "processes"
From this, and many different processes, laws are inferred but all this takes place on a time scale.
Questions:
- What happens when the inference times are longer than then interaction times? Then this scheme fails.
- What happens when the postprocessing capacity required to reach the best abduction exceeds the capacity of the observing context?
Both these questions are avoided when we study small, short lives subsystems. This is why the current paradigm works. But it leaves us with scratching our heads about a few things; how are the in this ways effective laws understood in a coherent way? How to include gravity which is a slow process by comparasion.
With this thinking, the conceptual distinction of real symmetries vs reduncancies become less simple I think.
/Fredrik
Whether or not your comment really belongs in the interpretations subforum, it's off topic in this thread. This thread is about a specific concept in standard QM, not about meta-meta-meta questions about how we come up with models or how we do science. (Even in the interpretations subforum meta-meta-meta questions can be off topic.)
Likes zb23, Fra and vanhees71
Related to Is the concept of "potential" just a mathematical model?
1. What is the concept of "potential"?
The concept of "potential" refers to the idea of something having the ability or capacity to become or develop into something else. It is often used in mathematics and physics to describe the amount of energy or force that is stored or available in a system.
2. Is the concept of "potential" only a mathematical model?
No, the concept of "potential" is not just a mathematical model. While it is often used in mathematical equations and models, it also has real-world applications in fields such as physics, chemistry, and biology. It is a fundamental concept in understanding how energy and forces work in the natural world.
3. How is the concept of "potential" used in mathematics?
In mathematics, the concept of "potential" is often used to describe the energy or force that is stored in a system. It can also refer to the amount of work that can be done by a force in a given situation. For example, in the field of calculus, the concept of potential is used to calculate the potential energy of an object based on its position and the forces acting on it.
4. What are some examples of "potential" in everyday life?
There are many examples of "potential" in everyday life. For instance, a stretched rubber band has potential energy due to its stretched state, which can be released to do work. A ball at the top of a hill has potential energy due to its position, which can be converted into kinetic energy as it rolls down the hill. In chemistry, potential energy is stored in chemical bonds and can be released during a chemical reaction.
5. Is the concept of "potential" a universally accepted concept?
Yes, the concept of "potential" is a universally accepted concept in science. It is used in various fields, such as physics, chemistry, biology, and economics, to describe and understand the behavior of energy and forces. While there may be different interpretations and applications of the concept, the fundamental idea of something having the ability or capacity to become or develop into something else remains consistent.
