Is the conservation of energy a statistical phenomena?
In summary, the conversation discusses the possibility of violating the law of conservation of energy in two scenarios - through random motions of particles in a heat engine and on the quantum level. While the second law of thermodynamics is a statistical law and can be violated, energy conservation can only be violated for a limited amount of time according to Heisenberg's uncertainty principle.
mrspeedybob
869
65
Suppose you build a heat engine. On one side you have a hot body, on the other side you have a cold body. Between the 2 you have the heat engine but on a parallel path you have a simple heat conductor.
What will happen is that some of the heat will travel through and power the heat engine and some will travel through the heat conductor and do nothing until the 2 bodies are at the same temperature, but heat is just the magnitude of the random motions of atoms/molecules. It seems like it would be possible for random motions to result in heat transfer through the conductor until the hot body is hot again and the cold body is cold again, by pure chance. This would be so improbable that it would likely never be observed happening but I can't see a reason that it should be impossible.
Another scenario where extremely unlikely events could result in a violation of conservation of energy would be on the quantum level. It is my understanding that any given particle has a certain amount of inherent uncertainty in its position and momentum. If a significant percentage of an objects particles spontaneously and simultaneously decided they were going to exist a meter further up the gravity well from their current position that would be observed as a violation of the law of conservation of energy. Again, such an event would be so improbable that it would likely never be observed but improbable does not equal impossible.
So, as the title states, is the law of conservation of energy a fundamental law or the result of statistical probability?
In the first case, energy is conserved, but the second law of thermodynamics is not, and yes, the second law is a statistical law, it can be violated. The larger your system is, the less the fluctuations are percentage-wise. For most macroscopic situations the level of fluctuations is usually negligible, but if you are studying Brownian motion, for example, they will not be ignorable.
In the second case, yes, energy conservation can be violated but only for a certain amount of time. The relationship between the amount of energy violation and the time interval over which it occurs is given by Heisenberg's uncertainty principle.
Related to Is the conservation of energy a statistical phenomena?
1. What is the conservation of energy?
The conservation of energy is a fundamental law in physics that states energy cannot be created or destroyed, but can only be transformed from one form to another.
2. Is the conservation of energy a statistical phenomenon?
No, the conservation of energy is a universal law that applies to all physical systems, regardless of their size or complexity. It is not a statistical phenomenon, but rather a fundamental principle of nature.
3. How does the conservation of energy relate to statistical mechanics?
Statistical mechanics is a branch of physics that studies the behavior of large numbers of particles. The conservation of energy is a crucial component of statistical mechanics, as it allows for the prediction of the overall energy distribution of a system.
4. Can the conservation of energy be violated?
No, the conservation of energy has been extensively tested and has always been found to hold true. It is considered a fundamental law of nature and has never been observed to be violated.
5. Are there any exceptions to the conservation of energy?
The conservation of energy is a general principle that holds true in most physical systems. However, there are some rare cases, such as in quantum mechanics, where energy can briefly fluctuate or appear to violate the conservation of energy. These exceptions are allowed by the uncertainty principle and do not contradict the overall conservation of energy.
  • Thermodynamics
  • Astronomy and Astrophysics
