Is the de Broglie wavelenght incongruent with particle in a box calculation?
In summary, the conversation discusses the confusion regarding the application of the correspondence principle in QM, specifically in relation to the calculated energy and de Broglie wavelength of massive objects in a particle in a box. The conversation also addresses the concept of energy level spacing becoming continuous for massive objects and the discrepancy in energy calculations for massive objects in classical and quantum mechanics.
a dull boy
40
Dear Physics Forum,
I think I am confused in applying the correspondence principle in QM, using the particle in a box and de Broglie wavelength calculations for massive (macroscopic) objects.
Why is the calculated energy of a massive object so small in the particle in a box
E = h2/8mL2
but when the de Broglie wavelength of a massive object is calculated,
λ = h/p
it is very small, meaning its frequency and so energy are high?
And if the energy level spacing is always n2, why is it said that the spacing becomes continuous, not discrete, for massive objects?
Thanks for your help, Mark
The energy of the particle in a box is calculated by plugging in the wavefunction of the particle into the Schrodinger Equation. Since the potential energy inside the "box" is zero, the Schrodinger equation takes the form [tex] \frac {d^{2} \psi} {dx^{2}} + \frac {8 \pi m} {h^{2}} E \psi = 0 [/tex] The wavefunction of the particle is given by [tex]\psi = \sqrt{\frac{2}{L}} + sin \left ( \frac{n \pi x}{a} \right )[/tex] Substituting this into 1 gives you the equation for the energy levels of the particle that you posted (except that there should be an n2 next to h2).
When people say that it becomes continuous, it means that the difference in energy levels is so small that it appears to be continuous, as in classical mechanics.
If you combine your first post in a different way, you answer your own questions:
For macroscopic objects in macroscopic boxes, the energy levels are very close to each other. Therefore, any "macroscopic energy" is at very high n, where the relative distance between the levels is really small (relative distance of n^2 and (n+1)^2 is ~2/n and therefore falling for large n).
As the energy is large, the De-Broglie wavelength is very small and smaller than usual box sizes.
a dull boy said:
E = h2/8mL2
This is for the ground state, n = 1. For any n you have
E = n2h2/8mL2
For a non-relativistic particle with no potential energy (only kinetic energy), E = p2/2m (which you can verify from the usual classical formulas for momentum and kinetic energy).
1. Use de Broglie's formula λ = h/p to substitute for p and get a formula that gives E in terms of λ.
2. Recall that for the particle in a box, the length of the box is an integer multiple of half the wavelength: L = nλ/2. Use this to substitute for λ in the equation you found in step 1. What do you get for E?
Thanks very much for the help, I see the point that the relative spacing decreases with n, MarkM. I also did the substitutions you suggested jtbell, and did recreate the particle in the box equation from E = p2/2m. I guess that surprised me, as the energy in E= p2/2m increases with mass, but in E=n2h2/8mL2 the energy appears to decrease with mass. The math works out, but why (I apologize for not using the squared superscript properly, but nonetheless)? Can you help?
Thanks very much, Mark
The typical n increases with the mass. Write n as something like n=c*m, and you get E proportional to m for the quantum-mechanical treatment, too.
Related to Is the de Broglie wavelenght incongruent with particle in a box calculation?
1. What is the de Broglie wavelength?
The de Broglie wavelength is a concept in quantum mechanics that describes the wavelength of a particle. It is named after French physicist Louis de Broglie, who proposed that particles can also exhibit wave-like behavior.
2. How is the de Broglie wavelength calculated?
The de Broglie wavelength can be calculated using the formula λ = h/mv, where λ is the wavelength, h is Planck's constant, m is the mass of the particle, and v is the velocity of the particle.
3. What is the particle in a box calculation?
The particle in a box calculation is a theoretical model in quantum mechanics that describes a particle confined within a one-dimensional box. It is used to study the energy levels and wave functions of the particle.
4. How does the de Broglie wavelength relate to the particle in a box calculation?
In the particle in a box calculation, the de Broglie wavelength is used to determine the allowed energy levels and corresponding wave functions of the particle. It is an important factor in understanding the behavior of particles in confined spaces.
5. Is the de Broglie wavelength incongruent with the particle in a box calculation?
No, the de Broglie wavelength is not incongruent with the particle in a box calculation. In fact, the de Broglie wavelength is an essential component of the particle in a box calculation and is used to accurately predict the energy levels and wave functions of the confined particle.
