Is the determinant a linear operation?
In summary, the determinant is not a linear operation and does not have a simple relationship with the expectation operator. The inequality for the logarithm of the determinant does not hold in the same manner as it does for other random variables.
EngWiPy
1,368
61
Is the determinant a linear operation? I mean can we say that:
[tex]\mathbb{E}[\text{det}]=\text{det}[\mathbb{E}][/tex]
where E is the expectation operator?
Mathematics news on Phys.org
First impression says no, but I'm testing it out now, I might be wrong.
No, it's not. For instance, det(aM) = andet(M). And det(M+N) doesn't have any simple relationship to det(M) and det(N). (See, for instance, http://en.wikipedia.org/wiki/Matrix_determinant_lemma" .)
Ok, now we have this inequality:
[tex]\mathbb{E}\left[\log(X)\right]\leq\log\left(\mathbb{E}[X]\right)[/tex]
Can we say in the same manner that:
[tex]\mathbb{E}\left[\log\left(\text{det}\left\{H\right\}\right)\right]\leq\log\left(\text{det}\left\{\mathbb{E}\left[H\right]\right\}\right)[/tex]
Nope. Suppose H=((1 0), (0 1)) with 50% probability and ((-1 0), (0 -1)) with 50% probability. Both of those have determinant 1, so E[log det H] = 0. But E[H] = ((0 0), (0, 0)), with determinant 0, so log det E[H] = -infinity.
Ok, I see. Thanks a lot
FAQ: Is the determinant a linear operation?
What is a determinant?
A determinant is a mathematical operation that is used to calculate the properties of a square matrix, such as its inverse and eigenvalues. It is represented by vertical bars on either side of a matrix, and the result is a single number.
Yes, the determinant is a linear operation. This means that it follows the properties of linearity, such as the addition and scalar multiplication of matrices.
How do you calculate the determinant of a matrix?
To calculate the determinant of a matrix, you can use various methods such as the cofactor expansion method, the Laplace expansion method, or the Gaussian elimination method. The method used will depend on the size and complexity of the matrix.
What are the applications of the determinant?
The determinant has various applications in mathematics, physics, and engineering. It is used to solve systems of linear equations, calculate the area and volume of shapes, and determine the stability of systems, among other things.
Can the determinant of a matrix be zero?
Yes, the determinant of a matrix can be zero. This means that the matrix is singular and does not have an inverse. It also means that the matrix has dependent rows or columns and does not span the entire space.
