Is the distance between AB and BC the same using the given coordinates?
  • MHB
  • Thread starter mathdad
In summary, we can use the distance formula or show that the three points are collinear to prove that AB = BC. Additionally, the midpoint formula can be used to find the midpoint of a line segment and determine if a point is the midpoint. The locus of points equidistant from two given points can also be found by using the distance formula and arranging the resulting equation in point-slope form.
mathdad
1,283
Given A(-4, 6), B(-1, 2), and C(2, -2), show that AB = BC.
Can I use the distance formula in this case?
Mathematics news on Phys.org
Yes, the distance formula would work, or if you can show the 3 points are collinear, then you could use the mid-point formula. :)
Can you show me your way?
In order for three points to be collinear, we can pick any two distinct sets of two points from the set of three to form two line segments, and those two line segments will have the same slope if the three points are collinear.
What are the slopes of the line segments $\overline{AB}$ and $\overline{BC}$ ?
Please attach the images inline...otherwise they won't show up in the "Topic Review" and having them show up there can be helpful when replying to a thread. Please see this thread:
http://mathhelpboards.com/questions-comments-feedback-25/attachment-image-line-21253.html
for instructions on posting attached images inline. :)
Let m = slope
(-4,6) and (-1,2)
m(AB) = (2-6)/(-1-(-4))
m(AB) = (-4)/(-1+4)
m(A,B) = -4/3
(-1,2) and (2,-2)m(BC) = (-2-2)/(2-(-1))
m(BC) = (-4)/(2+1)
m(BC) = -4/3
I see that m(AB) = m(BC).
What does this tell me?
This does not work for me. I do not have a computer. I tried several times. It let's me select from my files but does not me upload the selected image.
I use my cell phone for all my internet work. I honestly do not have a computer in my room. What is wrong with uploading images by MathMagic Lite as I have been doing so far.
RTCNTC said:
Let m = slope
(-4,6) and (-1,2)
m(AB) = (-4)/(-1+4)
m(A,B) = -4/3
m(BC) = (-4)/(2+1)
m(BC) = -4/3
It tells you the three points are collinear...now, is point $B$ the midpoint of $\overline{AC}$ ?
How can I tell if point B is the midpoint of line segment AC?
Use the midpoint formula with the endpoints of $\overline{AC}$ and see if the resulting coordinates match those of point $B$. :)
Suppose the three given points were not collinear...can you think of a plan that would still allow you to use the midpoint formula?
From now on, no more than two math questions whenever I decide to visit the MHB. I feel that less questions per visit leads to a more thorough reply and discussion per question.
As a follow-up to everything I posted, let's first find the mid-point $\left(x_M,y_M\right)$ of $\overline{AC}$:
\(\displaystyle \left(x_M,y_M\right)=\left(\frac{-4+2}{2},\frac{6+(-2)}{2}\right)=(-1,2)\)
This is point $B$ and so we know:
\(\displaystyle \overline{AB}=\overline{BC}\)
Now, suppose we have two points in the plane, points $A=\left(x_A,y_A\right)$ and $C=\left(x_C,y_C\right)$. Now, the locus of all points $B=\left(x_B,y_B\right)$ equidistant from both $A$ and $C$ can be found by using the distance formula:
\(\displaystyle \left(x_B-x_A\right)^2+\left(y_B-y_A\right)^2=\left(x_B-x_C\right)^2+\left(y_B-y_C\right)^2\)
Expand:
\(\displaystyle x_B^2-2x_Ax_B+x_A^2+y_B^2-2y_Ay_B+y_A^2=x_B^2-2x_Bx_C+x_C^2+y_B^2-2y_By_C+y_C^2\)
Combine like terms:
\(\displaystyle -2x_Ax_B+x_A^2-2y_Ay_B+y_A^2=-2x_Bx_C+x_C^2-2y_By_C+y_C^2\)
Arrange linear equation in point-slope form:
\(\displaystyle y_B-\frac{y_A+y_C}{2}=\frac{x_C-x_A}{y_C-y_A}\left(x_B-\frac{x_A+x_C}{2}\right)\)
As we should expect, we see this is the line perpendicular to the segment $\overline{AC}$ and passing through the midpoint of $\overline{AC}$. (Yes)
Mark:
Wonderful job!
FAQ: Is the distance between AB and BC the same using the given coordinates?
What are the coordinates for points A, B, and C?
The coordinates for points A, B, and C will depend on the given context of the question. In general, coordinates refer to a set of numbers that determine the location of a point in a coordinate system, such as x and y coordinates on a graph.
What does the distance between AB and BC represent?
The distance between AB and BC represents the length of the line segment connecting points A and B, and points B and C, respectively. This is also known as the distance between two points.
How is the distance between AB and BC calculated?
The distance between AB and BC can be calculated using the distance formula, which is the square root of the sum of the squares of the differences between the x and y coordinates of the two points. Alternatively, the Pythagorean theorem can also be used to calculate the distance between two points.
Is the distance between AB and BC the same in all coordinate systems?
No, the distance between AB and BC may vary depending on the type of coordinate system being used. For example, in a Cartesian coordinate system, the distance between two points is measured using the Euclidean distance formula, while in a polar coordinate system, the distance between two points is measured using the polar distance formula.
Can the distance between AB and BC be negative?
No, the distance between two points cannot be negative. Distance is a measure of length and is always positive. However, the difference between the coordinates of points A and B, or points B and C, can be negative if the points are located on opposite sides of the axis in a coordinate system.
