Is the following decay process possible?
In summary: In your original post, you only mentioned total lepton number. So it would be helpful if you could revise your summary to mention flavor conservation as well.In summary, an antimuon and electron can bind together via Coulomb attraction and then decay. The process (µ+e-) → νe + νµ_bar is possible since both electron-lepton number and muon-lepton number are conserved. However, flavor conservation is not always applicable to neutrinos, so the decay mode may proceed naturally.
says
594
An antimuon and electron may bind together via Coulomb attraction and then decay, but is the following process possible? (µ+e-) → νe + νµ_bar
*The νµ_bar is the antiparticle of the muon neutrino - the antimuon neutrino
More than one answer (below) may be correct.
a) This decay mode can proceed naturally.
b) This decay would violate electron-lepton number. 0 + 1e → 1e + 0
c) This decay would violate muon-lepton number. -1μ + 0 → 0 - 1μ
d) This decay would violate tau-lepton number. 0 + 0 → 0 + 0
e) This decay would violate charge conservation. +1 - 1 → 0 + 0
Lepton numbers, charge, conservation
+e-) → νe + νµ_bar
µ+: lepton number: -1
e-: lepton number: +1
νe: lepton number: +1
νµ_bar: lepton number: -1
(-1µ++1e-) → +1νe + 1νµ_bar
electron-lepton number and muon-lepton number is conserved. There are no tau's in the equation. Therefore, b),c),d) are incorrect.
µ+ charge = +1
e- charge = -1
νe charge = 0
νµ_bar charge = 0
(+1µ+-1e-) → 0νe + 0νµ_bar
The net charge on both sides of the equation equals zero. Therefore, e) is incorrect.
So, by that logic I'd say the answer is a) This decay mode can proceed naturally.
The electron number Le and the antimuon number Lµ+ are the same on both sides. (antimuon and antimuon neutrino both have a lepton number of -1)
You are missing the point.
As well as overall lepton number conservation, there is also conservation of the three flavors of lepton number separately. Those flavor conservations do not always apply - e.g. random switching of neutrinos between flavors - but do apply in most interactions.
Reread the text at the link I posted.
I've re-read the link and understand that flavor conservation does not always apply with neutrinos. I don't think I understand the point you're trying to make.
But do you understand that it is conserved in most interactions?
Is the "lepton electron number" conserved in the process mentioned in post #1?
Yes it is. The electron and electron neutrino both belong to the Le flavor
Just noticed you have edited post #1 to clarify that. Originally you had only discussed total lepton number, so your reasoning was incomplete.
and lepton muon number is also conserved
Yes
Related to Is the following decay process possible?
1. Is the following decay process possible?
The possibility of a decay process depends on various factors such as the type of nucleus, its energy level, and the conservation laws of energy and momentum. Without specific details, it is difficult to determine the possibility of a decay process.
2. What are the conservation laws of energy and momentum?
The conservation laws of energy and momentum state that the total energy and momentum of a system remain constant before and after any physical process, including decay. This means that the sum of the energy and momentum of the decay products must be equal to the energy and momentum of the initial nucleus.
3. Can a decay process violate the conservation laws?
No, the conservation laws of energy and momentum are fundamental principles in physics and have been tested and verified in numerous experiments. If a decay process violates these laws, it would not be considered possible.
4. What determines the type of decay process that will occur?
The type of decay process is determined by the stability of the nucleus and the energy difference between the initial and final states. Nuclei with excess energy can release it through various types of decay, such as alpha, beta, or gamma decay.
5. How do scientists study and observe decay processes?
Scientists use various techniques such as particle accelerators, detectors, and spectroscopy to study and observe decay processes. These tools allow them to measure the properties of the decay products and understand the underlying physical processes involved.
  • Beyond the Standard Models
