Is the following equation a wave?
  • I
  • Thread starter Aritra Kundu
  • Tags
    Wave
In summary: A single pulse can constitute a wave when there is only one single excursion from the equilibrium condition.
Aritra Kundu
We know that a wave is represented by f(x - vt) and it follows the differential wave equation. e^(x - vt) satisfies both the condition. But is it really a wave? Because to sustain the wave we need infinite energy which is not possible. So what's happening here?
Not necessarily, if f=ln this is not a wave.
I assume you are referring to the complex exponential
$$e^{i(kx-\omega t)}$$.
Yes
Why do you think this wave requires infinite energy?
For the wave you have written down, I would agree with you - so long as the energy density of the wave increases with the wave amplitude ;)
Yes
No its not complex exponential.
And it requires infinite energy because at x --> infinity, the function tends to infinity. It's energy density increases with x. So it need to be supplied with energy for infinity.
Then it is not a wave. This is not a solution to the wave equation.
It satisfies the wave equation. You can check, by double differentiating it with x and t.
Looking at how the function varies with x or with t it seems to describe a function that increases without limit as x increases and tends to zero as t increases. Is that what you would describe as a wave? (Just giving it a reality check)
Not all Maths has meaning in the Physical World.
Yes, sorry about that. But it is not really a wave because what does ##\omega## signify here if there is no oscillation?
It is common practice to throw out solutions which do not satisfy boundary conditions. In this case it doesn't make sense for the solution to blow up as x goes to infinity.
NFuller said:
what does ωω\omega signify here if there is no oscillation?
There needn't be any oscillation. A single pulse can constitute a wave when there is only one single excursion from the equilibrium condition.
But you are right to say that you always need to apply boundary conditions.
Likes davenn
This would consist of many values of ##\omega## via a Fourier transform of a delta function. The issue here is what does e^(##\omega t##) signify being purely real?
The frequency domain is a valid way to express a wave but a single pulse involves an infinite number of frequency components (the harmonics of zero fundamental) and the pulse is not 'periodic'. The use of a particular symbol (ω) doesn't actually imply periodicity and the OP is referring to a Real Function (afaics).
Btw, the delta function need not be involved here.
Related to Is the following equation a wave?
1. What is a wave?
A wave is a disturbance or oscillation that travels through space and matter, transferring energy without permanently displacing the medium.
2. How can you tell if an equation represents a wave?
An equation represents a wave if it has a sine or cosine function and shows periodic behavior, with a repeating pattern of peaks and troughs.
3. What are the characteristics of a wave?
A wave is characterized by its amplitude, wavelength, frequency, and speed. Amplitude is the maximum displacement of the wave from its equilibrium position, wavelength is the distance between two consecutive points on the wave with the same phase, frequency is the number of complete waves that pass a given point in one second, and speed is the rate at which the wave travels through the medium.
4. Can an equation that represents a wave also represent other types of functions?
Yes, an equation that represents a wave can also represent other types of functions, such as trigonometric, exponential, or logarithmic functions. However, in order for an equation to accurately represent a wave, it must have the characteristics of a wave (as mentioned in question 3).
5. How are waves used in science?
Waves are used in science to study and understand various phenomena, such as sound, light, and electromagnetic radiation. They are also used in fields such as acoustics, optics, and electromagnetic theory. In addition, waves play a crucial role in communication technology, as they can be used to transmit information over long distances.
  • Classical Physics
  • Other Physics Topics
  • Differential Equations
  • Quantum Physics
