Is the Fourier Transform of x(t)=1 equal to X(jω)=2πδ(ω)?
In summary, the author argues that the Fourier transform of a single impulse of area 2π at ω=ω0 is X(jω)=2πδ(ω) and that this corresponds to the signal x(t) that is the Fourier transform of x(t)=ejω0t. However, this result only satisfies the first equation and not the second.
asmani
105
Hi all
I know that the Fourier transform of x(t)=1 is X(jω)=2πδ(ω) by using the duality property.
This implies:
[tex]\int_{-\infty }^{+\infty }e^{-j\omega t}dt=2\pi\delta(\omega)[/tex]
Consequently, for ω≠0:
[tex]\int_{-\infty }^{+\infty }e^{-j\omega t}dt=0[/tex]
And as a result:
[tex]\int_{-\infty }^{+\infty }\cos t\: dt=0[/tex]
Is this result true?!
Thanks in advance
Yes.
But intuitively you should be able to solve this also: the amplitude is constant so this translates to an impulse in the opposite domain which is a single frequency in frequency domain, or a frequency domain impulse function.
Similarly, in the frequency domain, a A(w)=1 corresponds to a time-domain impulse function - all frequencies represented.
These are duals.
asmani said:
Hi all
This implies:
And as a result:
it depends on what you really mean by "true".
mathematicians will have trouble with anything you wrote here. the integrals do not converge. you *can* say that
[tex]\lim_{B \rightarrow + \infty}\frac{1}{2B} \int_{-B }^{+B }\cos t \ dt = 0[/tex]even the electrical engineering use of the dirac impulse function, [itex] \delta(t) [/itex] is not kosher, from the POV of strict mathematicians. someday, you might take a course in Real Analysis and you will learn that if
[tex] f(t) = g(t) [/tex]
"almost everywhere" (that is, everywhere except for a countable number of discrete points), then
[tex] \int f(t) \ dt = \int g(t) \ dt [/tex]
but we are saying that [itex] \delta(t) = 0 [/itex] almost everywhere, yet the integral of [itex] \delta(t) [/itex] is 1 and the integral of 0 is 0, not the same.
the mathematicians don't even grant the Dirac delta function the unqualified label "function". they call it a "distribution", party because you cannot have a (true) function that is zero everywhere except for one point and have its integral be anything other than zero.
when i do electrical engineering, i do treat the Dirac impulse function as a function, in the sense we commonly do in electrical engineering (it's zero almost everywhere, but its integral is 1), but i know that this doesn't fly, given the language and definitions that the mathematicians give things.
so, my advice is just to be careful with what you say and whom you say it to.
Thanks for the replies.
I just followed the definitions of Oppenheim Signal and Systems.
The Fourier transform pair represented in this book:
[tex]x(t)=\frac{1}{2\pi}\int_{-\infty}^{+\infty }X(j\omega)e^{j\omega t}d\omega
[/tex]
[tex]
X(j\omega)=\int_{-\infty}^{+\infty }x(t)e^{-j\omega t}dt
[/tex]
Now the question is do x(t)=1 and X(jω)=2πδ(ω) satisfy these equations?
On page 297 of this book (second edition):
To suggest the general result, let us consider a signal x(t) with Fourier transform X(jω) that is a single impulse of area 2π at ω=ω0; that is [tex]X(j\omega)=2\pi\delta(\omega - \omega_{0})[/tex]
To determine the signal x(t) for which this is the Fourier transform, we can apply the inverse transform relation, eq. (4.8), to obtain [tex]x(t)=\frac{1}{2\pi}\int_{-\infty}^{+\infty}2\pi\delta(\omega - \omega_{0})e^{j\omega t}d\omega=e^{j\omega_0 t}[/tex]
After this, X(jω)=2πδ(ω-ω0) is considered as the Fourier transform of x(t)=e0t. Is it a valid argument? This pair only satisfy the first equation.
FAQ: Is the Fourier Transform of x(t)=1 equal to X(jω)=2πδ(ω)?
What is a Fourier transform?
A Fourier transform is a mathematical operation that decomposes a function in terms of its frequency components. It converts a function from its original domain (e.g. time or space) to its frequency domain.
How is a Fourier transform calculated?
The Fourier transform of a function is calculated by integrating the function with a complex exponential function over the entire domain. This integral is also known as the inverse Fourier transform. The result is a complex-valued function that represents the frequency components of the original function.
What does x(t) = 1 represent in the Fourier transform?
The function x(t) = 1 represents a constant value of 1 over the entire domain. This means that the Fourier transform will have a single spike at the origin in the frequency domain, with an amplitude of 1. This represents the fact that the constant function has no variation in frequency.
Why is the Fourier transform useful?
The Fourier transform is useful in many areas of science and engineering. It allows us to analyze signals and functions in terms of their frequency content, which can provide valuable insights and information. It is also used in signal processing, image processing, and data compression.
What is the relationship between a function and its Fourier transform?
The Fourier transform is a mathematical operation that maps a function from its original domain to its frequency domain. This means that the original function and its Fourier transform are two different representations of the same underlying information. The Fourier transform provides a different perspective on the function, allowing us to analyze its properties in the frequency domain.
