Is the function differentiable at x = p?
In summary, the function f(x) = (2^x - 1)/x is not differentiable at x = 0 because it is not defined there. However, by setting a specific value for f(0), the function becomes not just differentiable, but analytic. This is because the singularity at the origin is removable.
PcumP_Ravenclaw
106
Hello mates,
is the function ## f(x) = \frac{(2^x - 1)}{x} ## differentiable at x = 0? For it to be differentiable it has to be continuous? From the graph f(0) is undefined although limit exists. I have read that at points like a corner, gap and vertical tangents it is not differentiable. So why is it differentiable at f(0)?
Sehr Danke!
Quotient rule:
if ##f(x) = g(x) / h(x)##, ##g(x) = 2^x - 1## and ##h(x) = x## then ##f'(x) = (h(x) * g'(x) - g(x) * h'(x) / g(x)^2##. In this case, ##g(x)^2 = 0## so the derivative would be undefined. Does this help?
PcumP_Ravenclaw said:
Hello mates,
No.
This function isn't defined at x = 0, hence it's not continuous at x = 0, so it can't be differentiable there.
Sehr Danke!
However, ##\displaystyle \ \lim _{x\to0} f'(x)\ ## does exist.
Likes fresh_42
Isaac0427 said:
Quotient rule:
This assumes ## g \neq 0 ## which is not the case, like many said. You may say that _at points where ##g \neq 0 ##_ (since both ## f,g## are everywhere differentiable), you can say ## (f/g)' = \frac {f'g-fg'}{g^2}= \frac {(ln2)(2^x)x -2^x}{x^2} ##, using the identity ## 2^x = e^{xln2}##.
Hello mates,
Sehr Danke!
Functions can only be differentiable where they are actually defined. However the singularity at the origin is removable by setting [itex]f(0) = \ln 2[/itex]. Then the function is not merely differentiable at the origin but analytic, and its Taylor series is [tex]
f(x) = \sum_{n=0}^\infty \frac{(\ln 2)^{n+1} x^n}{(n+1)!}.[/tex]
Likes fresh_42, SammyS and HallsofIvy
Related to Is the function differentiable at x = p?
1. What does it mean for a function to be differentiable at a point?
When a function is differentiable at a point, it means that the derivative of the function exists at that point. In other words, the slope of the tangent line to the function at that point can be found.
2. How can I determine if a function is differentiable at a specific point?
To determine if a function is differentiable at a specific point, you can use the definition of differentiability, which states that the limit of the difference quotient (f(x+h)-f(x))/h as h approaches 0 must exist and be finite.
3. Can a function be differentiable at a point but not continuous?
No, a function cannot be differentiable at a point if it is not continuous at that point. This is because differentiability requires the existence of a limit, which cannot exist if the function is not continuous.
4. What is the difference between differentiability and continuity?
Differentiability and continuity are related concepts, but they are not the same. A function is continuous at a point if it has a defined value at that point and the limit of the function as x approaches that point exists. On the other hand, a function is differentiable at a point if the derivative of the function exists at that point.
5. Can a function be differentiable for some values of x but not others?
Yes, a function can be differentiable at some values of x and not others. This can happen when a function has a corner, cusp, or vertical tangent at a certain point, making the derivative undefined at that point. However, the function may still be differentiable at other points where the derivative exists.
