- 1,252
- 940
- TL;DR Summary
- Is the Gamma-factor for Tachyons real, as stated in the paper?
I found in a paper:
Source (see page 35 and also chapter 4.1.2):
https://scipost.org/SciPostPhysLectNotes.10/pdf
Is this correct, and if yes, why? They use the (-+++) convention.
paper said:4.1.4 Tachyons
If ##v>1##, that is, the particle is moving faster than the speed of light, then the norm of the 4-velocity (165) will necessarily be##|\dot x|^2>0## and thus the path must be spacelike. In that case we can normalize to##|\dot x|^2=1##, which gives (50)
##\gamma = \frac {1}{\sqrt{v^2-1}}##
(50) Note that the Lorentz factor is real, as it should be. Naively, if one used the definition of ##\gamma## which was derived by assuming ##v<1##, then ##\gamma## will be imaginary for ##v>1##; but that is simply not the right normalization factor to use.
Furthermore, since ##\gamma## is real, so is the energy ##E=\gamma m##. A tachyon need not have imaginary energy or mass, as is sometimes naively claimed.
