Is the Gradient Vector Only Applicable for Multivariable Functions?
In summary, the conversation discusses the interpretation of the gradient vector in vector calculus, specifically its role in finding a normal vector to a curve. It is mentioned that the gradient only exists for functions with more than one variable and that the first derivative of a single-variable function gives the slope of the tangent to the curve. To find the slope of the normal, one can use the formula n = -1/m = -1/dy/dx = -dx/dy, provided that dy/dx is not equal to zero.
Telemachus
835
30
Hi there. I have a doubt that I never cleared before, so I wanted your opinions on this. The thing is that when in vector calculus the gradient vector is presented, one of the "geometric" interpretation that is given is that it's a vector always perpendicular to the curve. So at first I've always tried to think in simpler cases when I have to face something new. I've tried going down one dimension. I always tried to think of this with a parabola of equation
[tex]y=x^2[/tex]
The thing is that if we think of the gradient for this parabola what we get its only the derivative, which is the slope of the curve. Of course, I would need another variable for y to get a vector pointing on the normal direction to the curve. So, how does this must be reasoned? how one gets the gradient vector for one variable functions? I thought that maybe involving the implicit function theorem I could get on something, but didn't get too far. The other idea requires to "extend" the function on two variables, thinking of it as the intersection of a surface with a plane.
Is it that the gradient only exists for functions of more of one variable? now that I wrote all this I'm thinking that the interpretation of the gradient as a vector normal to the curve (or the surface) perhaps only holds for two dimensional curves, because if we go one dimesion over then we can't think in something like the normal vector, right? and with one dimension less we only get the slope for the curve.
So what you say?
Bye there, thanks for posting.
The first derivative of a function of a single variable gives an expression for the slope of the tangent to the curve of that function. From the text of your question, it appears that you are looking to find a normal to the curve instead of a tangent.
If y = f(x), then dy/dx| x = x0 gives the slope m of the tangent at x = x0
To find the slope n of the normal, n = -1/m = -1/dy/dx = -dx/dy provided that dy/dx is not equal to zero at x = x0.
The gradient of a single-variable function would indeed be the derivative (or rather, a vector with the same magnitude as the derivative).
Thanks.
FAQ: Is the Gradient Vector Only Applicable for Multivariable Functions?
What is a gradient in one variable?
A gradient in one variable represents the slope or rate of change of a function with respect to that variable. It is a measure of how much the output of a function changes as the input variable increases.
How is the gradient in one variable calculated?
The gradient in one variable is calculated by finding the derivative of the function with respect to the variable. This can be done using the power rule, product rule, quotient rule, or chain rule depending on the complexity of the function.
What does a positive gradient in one variable indicate?
A positive gradient in one variable indicates that the function is increasing as the input variable increases. This means that as the input variable increases, the output of the function also increases.
What does a negative gradient in one variable indicate?
A negative gradient in one variable indicates that the function is decreasing as the input variable increases. This means that as the input variable increases, the output of the function decreases.
How can the gradient in one variable be used in real-life applications?
The gradient in one variable can be used to model and analyze various real-life situations, such as the rate of change of a stock price over time, the slope of a hill or road, or the speed of an object in motion. It can also be used to optimize functions and find maximum or minimum values.
