Is the Gravitational Constant a Tensor or a Constant Derived from Experiment?
In summary, the gravitational constant in Newton's equations represents the conversion factor between energy and the curvature of space-time. It is mostly derived from experiments and has units of m^3 s^{-2} kg^{-1}. It is also the term that multiplies the stress-energy tensor. The units of N(m/kg)^2 are not just for dimensional analysis, but represent force times distance squared over mass squared.
khemist
248
Is the gravitational constant in Newton's equations a description of the curvature of space time? if it is, does that mean it is a tensor, or simply a constant derived from experiment?
Its mostly the latter---a scalar constant derived from experiment. But it does have a more physical meaning: its the term that multiplies the stress-energy tensor, so its a conversion factor between standard units of energy and the curvature of space-time.
does that mean the constant has units, say of Newtons?
edit: i just looked at wikipedia, and it says it has units or N(m/kg)^2.
Are those units there to simply make the dimensional analysis work?
No, its has units of [tex]m^3 s^{-2} kg^{-1} [/tex] in mks, which is force times distance squared over mass squared
Just think about how you could end up with a force in Newton's equation [tex] F_g = G \frac{m_1 m_2}{r^2} [/tex]
sweet thanks for the quick replies.
FAQ: Is the Gravitational Constant a Tensor or a Constant Derived from Experiment?
What is the gravitational constant?
The gravitational constant, denoted as G, is a physical constant that represents the strength of the gravitational force between two objects with mass. It is a fundamental constant in physics and is used to calculate the force of gravity between objects.
How is the gravitational constant measured?
The gravitational constant is measured through various experiments, such as the Cavendish experiment, which involves measuring the tiny attraction between two masses using a torsion balance. It can also be calculated by using the mass and distance of two objects and using Newton's law of universal gravitation.
Why is the gravitational constant important?
The gravitational constant is important because it allows us to understand and predict the behavior of objects in the universe. It is used in many equations and theories, such as Newton's law of gravitation and Einstein's theory of general relativity.
Does the gravitational constant ever change?
As of current scientific understanding, the gravitational constant is considered to be a constant value. However, some theories suggest that it may vary in extreme conditions, such as in the early universe or near black holes.
Can the gravitational constant be modified?
The gravitational constant is a universal constant and cannot be modified by humans. However, some scientists are researching ways to potentially modify gravity itself through advanced theories and experiments, which may indirectly affect the gravitational constant.
32K
