Is the Higgs Field Manipulable?
In summary: Rather, the Higgs field is an example of a scalar field, which is a type of quantum field that has no directionality associated with it. It is still possible that the Higgs field is not exactly uniform and that there are small variations in its value in different regions of the universe, but these variations would be much smaller than those that exist in spacetime due to the presence of matter and energy. In summary, the Higgs field is a real thing that is responsible for giving mass to elementary particles through the Higgs mechanism. It is constant and uniform throughout the universe, but can be manipulated and its excitations can be observed through experiments at the LHC. It is not the same as spacetime and does not have the same properties
jonatron5
29
So with my admittedly very limited understanding of this level of physics I understand Mass to be caused by the interaction of the higgs boson with this field, and supposedly the experimental data in atom smashers has confirmed the existence of the boson, so accepting that higgs field is a real thing as well. I was curious as to whether it is something that is constant, or if it can be warped and stretched like space can be? If its not 100% uniform throughout the entire universe that means it can be manipulated. Or is my understanding fundamentally flawed, and the "field" is just a name for an abstract concept?
First of all only about 2% of the mass of the matter surrounding us is described by the Higgs mechanism, which should be named Anderson-Higgs-Kibble-Brout-Englert-Hagen-Guralnik mechanism, because all these people proposed it around the same time as a way to provide mass to the fundamental particles (most importantly the gauge bosons of the weak interaction, the W and Z bosons but also the quarks and leptons) without destroying the local gauge symmetry upon which the entire theory is built. Violating this symmetry would make the entire construct useless and contradictory. The other 98% of the mass of the matter surrounding us in everyday life is due to the strong interaction and Quantum Chromodynamics. It is the still not completely understood mechanism of confinement that is creating this mass dynamically. It's, however, known to be the right description from lattice-QCD calculations which leads to a correct prediction of the hadron spectrum within a few percent nowadays, and one can expect this results to become even more accurate with further developments in both hardware and software.
In the Standard Model the mass of the elementary constituents due to the Higgs mechanism is explained as the interaction of the particles with the Higgs field, which has a non-zero vacuum expectation value. By construction this vacuum expectation value is constant in space and time since the vacuum state by assumption is homogeneous and isotropic.
As with any field in a quantum field theory its excitations above the vacuum state should manifest itself as particles, and this was predicted by Higgs, Brout, and Englert and lead to the Nobel prize for Higgs and Englert after the discovery of this Higgs boson. In the meantime more data have confirmed that this Higgs boson has all the properties predicted by the Standard Model. So, indeed, the field can be "manipulated" by smashing protons at the very high energies available at the LHC, and this "manipulation" manifests itself as the creation of the very short-lived Higgs bosons, which can be observed by measuring accurately the energy and momenta of its decay products. The big challenge of the experimentalists is to filter out these decay products from all the other sources, where these particles might come from, and at these energies this "background" is tremendous.
Yes, but that's not the same as "warping and stretching". The Higgs field is not the same thing as spacetime, and it is not best viewed as having curvature the way spacetime in GR does.
Related to Is the Higgs Field Manipulable?
1. What is the Higgs Field and why is it important in physics?
The Higgs Field is a fundamental field in particle physics that is responsible for giving particles their mass. It is important because it helps to explain why different particles have different masses and how they interact with each other.
2. What does it mean for the Higgs Field to be "warpable"?
To say that the Higgs Field is "warpable" means that it has the ability to be altered or manipulated in some way. This could potentially have significant implications for our understanding of the universe and the behavior of particles.
3. How do scientists study the Higgs Field and its properties?
Scientists study the Higgs Field and its properties through experiments conducted at particle accelerators, such as the Large Hadron Collider. They also use mathematical models and theories to make predictions about the behavior of the Higgs Field.
4. What are some potential consequences if the Higgs Field is found to be warpable?
If the Higgs Field is found to be warpable, it could potentially open up new possibilities for manipulating matter and energy. It could also lead to a deeper understanding of the fundamental forces of nature and the structure of the universe.
5. Is there any evidence to suggest that the Higgs Field is warpable?
At this point, there is no conclusive evidence to suggest that the Higgs Field is warpable. However, some theories and models in particle physics do suggest the possibility of a warpable Higgs Field, and further research and experimentation may provide more insight into this question.
  • Beyond the Standard Models
