Is the integer ## (447836)_{9} ## divisible by ## 3 ## and ## 8 ##?
  • Thread starter Thread starter Math100
    Integer
The integer (447836)_{9} converts to 268224 in decimal form. It is confirmed that the sum of its digits, 2+6+8+2+2+4, equals 24, which is divisible by both 3 and 8. Therefore, (447836)_{9} is divisible by 3 and 8. Additionally, it is noted that for base 9, checking the last digit suffices to determine divisibility by 3. The discussion highlights that while the sum of digits can indicate divisibility by 8, it is not a reliable method for all numbers.
Math100
None.
Observe that ## (447836)_{9}=6+3\cdot 9+8\cdot 9^{2}+7\cdot 9^{3}+4\cdot 9^{4}+4\cdot 9^{5}=268224 ##.
Then ## 2+6+8+2+2+4=24 ##.
Thus ## 3\mid (2+6+8+2+2+4)\implies 3\mid (447836)_{9} ## and ## 8\mid (2+6+8+2+2+4)\implies 8\mid (447836)_{9} ##.
Therefore, the integer ## (447836)_{9} ## is divisible by ## 3 ## and ## 8 ##.
Math100 said:
Homework Statement:: Is the integer ## (447836)_{9} ## divisible by ## 3 ## and ## 8 ##?
Relevant Equations:: None.
Correct. How do you check that a number is divisible by eight?
Likes Math100
It's a well-known fact that if the digits of a decimal number (i.e., in base-10) add up to 3 or a multiple of 3, then the number itself is divisible by 3. It's also a fact that if the digits of the same number add up to 9 or a multiple of 9, then the number is divisible by 9.
You wrote ## 3\mid (2+6+8+2+2+4)\implies 3\mid (447836)_{9} ## twice. You don't need to do that. Also, and fresh_42 beat me to it, why is it the case that 8 divides (2+6+8+2+2+4)? This is not at all obvious.
I haven't thought about that. Do you know how? In this given question/problem, it's obvious since ## 24 ## is divisible by both ## 3 ## and ## 8 ##. But when it comes to large integers, do you know any rule?
## 8 ## divides ## (2+6+8+2+2+4) ## because ## 8\mid 24 ##.
Clearly, but does 8 divide 268,224?
This is wrong. We know that ##8\,|\,1000## and any number ##a_na_{n-1}\ldots a_1=a_na_{n-1}\ldots a_4\cdot 1000 + a_3a_2a_1.## So what is the rule?
There are two other facts that I didn't mention:
If 4 divides that last two digits of a decimal number (i.e., the digits in the ten's and one's places), 4 divides the number.
If 8 divides that last three digits of a decimal number, 8 divides the number.
Likes Math100
Yes, since ## 224 ##, the last three digits of ## 268,224 ## is divisible by ## 8 ##.
Likes Delta2 and fresh_42
I've never seen this before. What is this rule?
##8## divides all thousands, so we have to check whether ##8## divides the last number formed by the last three digits. If ##n\,|\,a## then ##n\,|\,(a+b) \Longleftrightarrow n\,|\,b.##
Likes Math100 and Delta2
Perhaps you could argue in a different way that 3 divides the given number in base 9. Because 3 divides 9 and 3 divides the last digit of the number which is 6.
Likes Math100 and fresh_42
Yes, ##(447836)_{9}## which is 268224 in base ten, is divisible by ##8##. Notice that ##4+4+7+8+3+6=32## which is divisible by ##8##. That is a valid test of divisibility by 8 for a base 9 number. The reason this works is that ##9\equiv 1\pmod 8##.
The fact that ## 8## divides ## 2+6+8+2+2+4 ## is merely a coincidence.
Take the decimal number ##267496##. It's divisible by ##8##, but the sum of those digits is not divisible by ##8##.
If I did my calculation correctly, that is ##(446837)_{9}## in base 9.
As for testing for divisibility by ##3## of a number written in base 9 : simply check the one's digit. After all, ##9\equiv 0\pmod 3## .
No need to convert to decimal representation.
Observe that ##(447836)_{9}=6+3\cdot 9+8\cdot 9^{2}+7\cdot 9^{3}+4\cdot 9^{4}+4\cdot 9^{5}\equiv 6\pmod 9##.
And 6 is equivalent to 0 .
Added in Edit:
I should have said: ##(447836)_{9}=6+3\cdot 9+8\cdot 9^{2}+7\cdot 9^{3}+4\cdot 9^{4}+4\cdot 9^{5}\equiv 6\equiv 0\pmod 3##.
We only needed to check the one's digit, base 9. This is similar to the test for divisibility by 5 or by ten in the case of decimal representation.
