Is the Integral of 1/sqrt(1-x^4) Expressible in Terms of Elementary Functions?
In summary, the integral $\int \frac{1}{\sqrt{1-x^4}}\;{dx}$ cannot be expressed in terms of elementary functions.
juantheron
247
$\displaystyle (3)\;\; \int \frac{1}{\sqrt{1-x^4}}dx$
Hi jacks, :)
This integral cannot be expressed in terms of elementary functions. See this.
Kind Regards,
Sudharaka.
Sudharaka said:
Hi jacks, :)
Kind Regards,
Sudharaka.
That is strong evidence, but is not water-tight as IIRC neither Mathematica nor Alpha implements the full Risch algorithm and will occasionally drop through to special functions where an elementary integral does exist.
CB
Chebyshev's theorem: If $a, b \in\mathbb{R}$ and $m,p,n \in\mathbb{Q}$ then the (indefinite) integral of $ x^m\left(a+bx^n\right)^p$ can be written in terms of elementary functions if and only if one of $p,~ (m+1)/n, ~p+ (m+1)/n ~\in\mathbb{Z}$. In our case we have $m=0, ~ p = -\frac{1}{2}, ~ a = 1, ~ b = -1$ and $n = 4$. Clearly $p = -\frac{1}{2} \not\in\mathbb{Z}, ~ (m+1)/n = \frac{1}{4} \not\in\mathbb{Z}$ and $p+(m+1)/n = -\frac{1}{4} \not\in\mathbb{Z}.$ Thus $\int \frac{1}{\sqrt{1-x^4}}\;{dx}$ cannot be written in terms of elementary functions.
FAQ: Is the Integral of 1/sqrt(1-x^4) Expressible in Terms of Elementary Functions?
What is integral?
Integral is a mathematical concept that represents the area under a curve in a graph. It is used to find the total value of a function over a given interval.
What is trig substitution?
Trig substitution is a technique used to simplify integrals involving trigonometric functions. It involves substituting a trigonometric expression for a variable in the integral.
How do you perform trig substitution?
To perform trig substitution, you first need to identify the appropriate substitution based on the integral. Then, you use trigonometric identities to rewrite the integral in terms of the substituted variable. Finally, you solve the new integral using standard techniques.
When should I use trig substitution?
Trig substitution is useful when dealing with integrals involving trigonometric functions, especially when the power of the trigonometric function is odd or the integral involves a radical expression.
What are some common trig substitutions?
Some common trig substitutions include sin2x = 1 - cos2x, tan2x = sec2x - 1, and sec2x = 1 + tan2x.
