Is the ionising power of alpha particles greater than that of gamma
In summary, an alpha particle decreases the number of protons and neutrons in a nucleus, and this change in nuclear composition affects the energy of a beta particle that is emitted.
kihr
102
I request for help in understanding the following:
Q1. Why is the ionising power of alpha particles greater than that of gamma rays?
Q2. Why does the ratio of neutrons to protons in a nucleus increase after the emission of
an alpha particle? I would like to have a quantitative idea, as I could not figure this
out myself.
Q3. How is the formula to be derived for the kinetic energy of electrons emitted during
beta decay?
Thanks
Q1) The ionizing power of an alpha particle is by a direct interaction of the alpha particle with the atomic electrons in the material or gas. The interaction rate is dependent on the alpha particle velocity, and the energy loss of the alpha particle is given by the Bethe Bloch equation.
http://en.wikipedia.org/wiki/Bethe_formula
Photons ionize only by the photoelectric effect or deep-core photoionization of bound electrons, or by Compton scattering off of free electrons. These electrons then ionize other electrons by scattering off atomic electrons.
http://en.wikipedia.org/wiki/Photoelectric_effect
http://hyperphysics.phy-astr.gsu.edu/HBASE/quantum/compeq.html
Q2) In alpha particle decay, both the number of protons and the number of neutrons in a nucleus are reduced by 2.
Q3) In beta decay, lepton number has to be conserved. Leptons include electrons, muons taus and 3 flavors of neutrinos, and their antiparticles. In negative beta decay, both an electron and an anti-neutrino are emitted. These two particles have to share the available energy. This leads to a continuous energy distribution for the electron, depending of the relative angle of the emitted electron and anti-neutrino..
For a discussion of the derivation, see
http://hyperphysics.phy-astr.gsu.edu/Hbase/nuclear/beta2.html
http://www.princeton.edu/~romalis/PHYS312/Beta_spectrum.pdf
Bob S
Thanks for the references which I will go through. In the meanwhile I would request for clarity with respect to Q 2, as I am still not able to figure out as to how the ratio of neutrons to protons goes up following the emission of an alpha particle. By working out the ratios of N/Z in either case (i.e. for the mother nucleus and the daughter nucleus) I am not able to come to this conclusion. Hence I would request your help on this. Thanks.
Hi kihr-
This URL discusses the decay of polonium 210 to lead 206 by alpha decay.
http://www.lbl.gov/abc/wallchart/chapters/03/1.html
The polonium nucleus has 126 neutrons and 84 protons: n/p = 126/84 = 1.5000
The lead nucleus has 124 neutrons and 82 protons: n/p = 124/82 = 1.5122
(126-2)/(84-2) = 124/82
Bob S
Thanks for the help as well as for the reference. Actually I was trying to work out a general way to derive the solution to my problem using Z, A, and N, but I could not make much of a headway. By taking actual examples of alpha decay, of course, is easy to understand! Let me research a little more.
Related to Is the ionising power of alpha particles greater than that of gamma
Is the ionising power of alpha particles greater than that of gamma?
Yes, the ionising power of alpha particles is greater than that of gamma. This is because alpha particles have a larger mass and charge, making them more likely to interact with and ionize atoms.
What is the difference between the ionising power of alpha particles and gamma rays?
The main difference is in their properties. Alpha particles have a larger mass and charge, while gamma rays have no mass and carry no charge. This difference in properties results in a difference in their ability to ionize atoms, with alpha particles having a greater ionising power.
How does the ionising power of alpha particles and gamma rays affect living organisms?
The ionising power of both alpha particles and gamma rays can damage living organisms by disrupting cellular structures and causing mutations in DNA. However, alpha particles are more damaging due to their greater ionising power and ability to penetrate deeper into living tissue.
Can the ionising power of alpha particles and gamma rays be shielded?
Yes, both alpha particles and gamma rays can be shielded using different materials. Alpha particles can be stopped by a sheet of paper or a few centimeters of air, while gamma rays require thicker materials such as lead or concrete to be stopped.
What are some applications of the ionising power of alpha particles and gamma rays?
Alpha particles and gamma rays have various applications in industries such as medicine, research, and energy production. They can be used for medical imaging, cancer treatment, sterilization of medical equipment, and detecting leaks in pipelines, among others.
