A Is the kinetic mixing gauge-invariant for non-Abelian gauge fields?
Ramtin123
Consider two non-Abelian gauge fields ##A_\mu^a## and ##A_\mu^{'a}## belonging to the same symmetry group. An example could be the SM electroweak isospin fields and another exotic SU(2) hidden sector where ##a=1, \dots 3##.
Is the kinetic mixing of the following form gauge-invariant?
$$ F_{\mu\nu}^a F^{'a\mu\nu} $$
where ## F_{\mu\nu}^a## and ## F_{\mu\nu}^{'a}## denote the corresponding field strength tensors.
What is the difference between this case and a usual non-Abelian kinetic term ## F_{\mu\nu}^a F^{a\mu\nu}##?
You need to have a different "gauge index" on the F' tensor than a. I think... But gauge fields always transform under the fundemantal representation, so I think FF' should be gauge invariant. Here is a paper on it https://arxiv.org/abs/1604.00044
We do have kinetic mixing if we have more than one abelian gauge symmetry.
That paper discusses kinetic mixing of an Abelian U(1) gauge field with the electroweak isospin fields as shown in equations (1.1) and (1.3). The Abelian field strength tensor ##X_{\mu\nu}## is gauge invariant. This is not true for non-Abelian field strength tensor ##F^a_{\mu\nu}##. But the bilinear ## F_{\mu\nu}^a F^{a\mu\nu}## is gauge-invariant.
In this paper Arxiv 2104.01871 [hep-ph] , in the introduction, it is claimed that non-Abelian kinetic mixing is not gauge invariant. But the author does not explain why.
  • The gauge indices are contracted ##tr (F_{\mu\nu}^a T^a F^{ 'b\mu\nu} T^b) = \frac{1}{2} F_{\mu\nu}^a F^{ 'a\mu\nu}##
  • I think you mean "gauge fields always transform under the adjoint representation".
Yes I did.
I did some calculations, the coupling constant ##g## is included in the transformation matrices, ##U(x) = \text{exp}(- \text{i} g\theta(x)^a T^a)##.
## \text{Tr} ( F^{\mu \nu} B_ {\mu \nu}) \to \text{Tr} (U F^{\mu \nu} U^\dagger V B_ {\mu \nu} V^\dagger) \neq \text{Tr} ( F^{\mu \nu} B_ {\mu \nu})## because ##U^\dagger V \neq I ## and ##U^\dagger V \neq I ## because of different gauge-couplings.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
