Is the length of the arm r in a polar coordinate a function of the angle?
In summary, the textbook says that ##\vec r (\theta) = r \hat r (\theta)##, where ##\hat r (\theta)## is the terminal arm (a position vector in some sense). It can be seen that both ##\vec r (\theta)## and ##\hat r (\theta) ## are function of ##\theta##; whereas, the length of the vector ##r## is not.
Leo Liu
353
156
My textbook says ##\vec r (\theta) = r \hat r (\theta)##, where ##\hat r (\theta)## is the terminal arm (a position vector in some sense). It can be seen that both ##\vec r (\theta)## and ##\hat r (\theta) ## are function of ##\theta##; whereas, the length of the vector ##r## is not. I understand that the unit vector r is a function of the angle because the direction of the arm is changing. However, I would like to know why the authors did not mention whether ##r## is a function of ##\theta##. Thank you in advance :).
Science news on Phys.org
##r## is to ##\theta## what ##x## is to ##y## in a cartesian coordinate system. They are independent coordinates. They can be related only if you try to describe a curve, for example the curve of a spiral ##r=a\theta##
However the unit vectors ##\hat r,\hat\theta## depend on ##\theta## while in a cartesian coordinate system the unit vectors ##\hat x,\hat y,\hat z## are constant and independent of the coordinates ##x,y,z##. This crucial subtlety is the cause of many errors by students when working with polar coordinates.
  • Love
Likes etotheipi, Leo Liu and vanhees71
Does ##r##, the distance from the origin, change if you change only ##\theta##?
You must be careful about what the different variables and symbols mean in the diagram. ##r## is not a vector. In the diagram, ##r## is the numerical distance between the origin and the point at the end of the vector ##\vec r##. ##\hat r(\theta)## is the unit vector in the direction at angle ##\theta##.
Likes vanhees71
This is slightly inconsistent. ##\vec r## is a function of ##r## as well as ##\theta##:
$$\vec r (r, \theta) = r \hat r (\theta)$$
Compare this with Cartesian coordinates:
$$\vec r (x, y) = x \hat x + y \hat y$$
Likes Leo Liu
It is hard to say what is a function of what. The diagram shows one possibility is the radius line, where ##\theta## is constant and yet ##r## varies. In that case, ##r## is not a function of ##\theta##. The notation of the equation ##\vec r (\theta) = r\hat r (\theta)## implies that, in the example of this equation, ##r## is a constant and is not a function of ##\theta##. Since ##r## is a constant, the vector ##\vec r (\theta) ## does not need to be considered a function of ##r##.
Likes Leo Liu
Probably not. But it does change if r is related to theta.
Your explanation is very succinct, thank you.
If ##r## is a function of ##\theta##, then that describes a curve in the plane, in the same way that ##y## as a function of ##x## describes a curve.
You must distinguish that from the use of ##r, \theta## as independent coordinates.
Likes etotheipi, vanhees71, Delta2 and 1 other person
## \hat {\bf r} ## is not a function of ## \hat {\bf \theta} ##. ## \hat {\bf r} ## is as independent of ## \hat {\bf \theta} ## as unit vector ## \hat {\bf i} ## is to ## \hat {\bf j} ##.
##\hat r## is not a function of ##\hat \theta##, yet it is a function of ##\theta##.
Likes Delta2
It's not clear in what sense those statements are true.
Let's use Cartesian basis vectors to describe the orthonormalized basis vectors referring to the polar coordinates, ##(r,\varphi)##. The position vector in terms of polar coordinates then reads
$$\vec{r}=\vec{r}(r,\varphi)=r (\cos \varphi,\sin \varphi).$$
The (normalized) tangent vectors to the coordinate lines are
$$\hat{r}=\partial_r \vec{r}/|\partial_r \vec{r}|=(\cos \varphi,\sin \varphi)$$
and
$$\hat{\varphi}=\partial_{\varphi} \vec{r}/|\partial_{\varphi} \vec{r}|=(-\sin \varphi,\cos \varphi).$$
Indeed these vectors depend on the polar angle ##\varphi##. It's also obvious when depicting the coordinate lines and the unit tangent vectors along them.
How about the equation r = a? r not a function of ##\theta##.
Note that ##\hat r## is a unit vector at the position identified by ##r, \theta##. @Leo Liu is talking about ##\hat r##, while you seem to be talking about ##r##.
Likes Leo Liu
$$\begin{cases}
\hat r=\hat i \cos \theta + \hat i \sin \theta\\
\hat \theta = -\hat i \sin \theta + \hat j \cos \theta
\end{cases}$$
Yes that relates polar unit vectors to cartesian unit vectors.
But sticking to just the polar coordinates, ## \hat {\bf r} ## is not a function of ## \hat {\bf \theta} ##.
A vector in polar coordinates is ## \bf f = \bf f_r(r,\theta) \hat {\bf r} + f_\theta(r,\theta) \hat {\bf \theta} ##.
If ## \hat {\bf r} = \hat {\bf r}(\theta) ## then the two terms above could not be independent of each other.
Maybe we're talking different things. Or maybe I'm just missing something.
rude man said:
But sticking to just the polar coordinates, is not a function of ##\hat{\theta}##.
Yes, but did anyone said otherwise? It is not function of ##\hat{\theta}## but it is a function of angle ##\theta## (without 'hat') because it points in different directions depending on that angle. The same goes with ##\hat{\theta}##. That's why formulas for velocity and acceleration are much more messier in polar coordinates.
Likes Ibix
On the contrary, we have:
$$\hat {\bf r} =
\begin{pmatrix} \cos \theta\\ \sin \theta \end{pmatrix} = \begin{bmatrix}
0 & 1 \\
-1 & 0 \\
\end{bmatrix}
\begin{pmatrix} -\sin \theta \\ \cos \theta \end{pmatrix}
= \begin{bmatrix}
0 & 1 \\
-1 & 0 \\
\end{bmatrix}
\hat {\bf \theta}
And a linear mapping is, by definition, a function.
Likes Ibix
You seem to be missing the distinction between the coordinates ##r,\theta## and the basis vectors ##\hat r## and ##\hat \theta##.
##r=\sqrt{x^2+y^2}## certainly is independent of ##\theta##. However, to insist that ##\hat r## is independent of ##\theta## is to insist that every radial vector is parallel to every other radial vector (for example, one pointing to 12 o'clock and one pointing to 3 o'clock). That's obviously wrong.
Sure, it's a function of ##\theta##, namely ##r(\theta)=a=\text{const}##. It describes a circle around the origin of the polar coordinate system with radius ##a##.
##\hat{r}## is the unit vector in radial direction and thus of course depends on ##\theta##. Without specifying ##\theta## it's not defined to begin with. In curvilinear coordinate systems the basis vectors often depend on the location they refer to. In the case of plane polar coordinates, the orthonormalized basis is
$$\hat{r}=(\cos \theta,\sin \theta), \quad \hat{\theta}=(-\sin \theta,\cos \theta),$$
expressed in terms of the usual Cartesian basis system the polar coordinates are defined in.
Likes dextercioby
Formulas for velocity and acceleration are messier in cylindrical coordinates because the unit vectors are time-dependent.
Yes, but that's because they depend on ##\theta## which is usually a function of time.
The unit vectors aren't time dependent for a stationary object, so the time dependence for a moving object clearly comes from the time variation of position.
Does that mean that the polar unit vectors will be different tomorrow?
Yes that's correct. At least they can be.
In fact, ## d\hat{\bf r}/dt = (d\theta/dt)~ \hat{\bf\theta} ## and
## d\hat{\bf\theta}/dt = - d\theta/dt ~ \hat{\bf r} ##.
But expressions for velocity and acceleration also have terms in them not a function of ##\theta ## or ## \hat{ \theta} ##.
For example, acceleration ##\bf a ## is
## \bf a = (d^2r/dt^2~ -... ~) ~ \hat{ \bf r} + ... +(d^2z/dt^2) \hat {\bf z}. ##
Well, for a moving object you have in polar coordinates ##r=r(t)## and ##\theta=\theta(t)##. For the position vector we have
$$\vec{r}=r \hat{r} \; \Rightarrow \; \vec{v}=\text{d}_t \vec{r} = \dot{r} \hat{r} + r \mathrm{d}_t \hat{r} = \dot{r} \hat{r} + r \dot{\theta} \partial_{\theta} \hat{r}=\dot{r} \hat{r} + r \dot{\theta} \hat{\theta},$$
where I've used that
$$\partial_{r} \hat{r}=0, \quad \partial_{\theta} \hat{r}=\hat{\theta}.$$
Further we need
$$\partial_{r} \hat{\theta}=0, \quad \partial_{\theta} \hat{\theta}=-\hat{r}.$$
With this we get
$$\mathrm{d}_t^2 \vec{r}=\mathrm{d}_t \vec{v} = \ddot{r} \hat{r} + 2 \dot{r} \dot{\theta} \hat{\theta} + r \ddot{\theta} \hat{\theta} -r \dot{\theta}^2 \hat{r}=(\ddot{r}-r \dot{\theta}^2) \hat{r} + (r \ddot{\theta} +2 \dot{r} \dot{\theta}) \hat{\theta}.$$
Related to Is the length of the arm r in a polar coordinate a function of the angle?
1. What is a polar coordinate?
A polar coordinate is a two-dimensional coordinate system used to locate points in a plane. It consists of a distance from the origin (r) and an angle from a reference direction (θ).
2. How is the length of the arm r determined in a polar coordinate?
The length of the arm r is determined by the distance from the origin to the point in question. This distance is measured in units such as meters or feet.
3. Is the length of the arm r always a function of the angle in a polar coordinate?
Yes, in a polar coordinate system, the length of the arm r is always a function of the angle θ. This means that for every value of θ, there is a unique value of r.
4. How is the angle θ measured in a polar coordinate?
The angle θ is measured counterclockwise from a reference direction, usually the positive x-axis. It is typically measured in radians or degrees.
5. Can the length of the arm r be negative in a polar coordinate?
No, the length of the arm r cannot be negative in a polar coordinate. It represents a distance from the origin, so it can only be positive or zero.
  • General Math
