Is the Lie derivative a tensor itself?
spinless
Hi everyone!
A few days ago in General Relativity class, the professor introduced the concept of Lie derivative and at the end he mentioned that the Lie derivative was a tensor itself. I've been looking everywhere, but I only find how it acts on vectors, tensors, etc. Does anyone know of any book/article/website that mentions this idea?
Thank you very much in advance!!
Here are some definitions:
https://www.physicsforums.com/insights/pantheon-derivatives-part-iv/#Lie-Derivatives
If ##X,Y## are vector fields, then ##\mathcal{L}_X(Y)=[X,Y]## which is again a vector field. ##\mathcal{L}## is linear in both arguments, so you may consider it a tensor. How it acts can be seen in the article I linked to.
Every derivative is a directional derivative. It measures variation in that direction. There are three main parameters: function, direction, and location. All of them can be the variable that results in different quantities: a number, a function, or even a field of directions. We abstract from function and location and consider directions alone in the case of vector fields.
Likes Astronuc, dextercioby and spinless
Moderator's note: Thread moved to the Differential Geometry forum.
spinless said:
Hi everyone!
The Lie derivative of a tensor is a tensor. Just like the derivative of a functions is a function.
spinless said:
Hi everyone!
You can find the general expression for the Lie derivative of a tensor with respect to some vector field ##\xi##. Just apply the definition, and perform a general coordinate transformation to see whether you get inhomogenous terms. E.g., for a vector field ##V## you obtain in component form
##L_{\xi} V^{\mu} = \xi^{\lambda} \partial_{\lambda}V^{\mu} -V^{\lambda}\partial_{\lambda}\xi^{\mu}##
If you're dealing without torsion, you can actually show that this equals
##L_{\xi} V^{\mu} = \xi^{\lambda} \nabla_{\lambda}V^{\mu} -V^{\lambda}\nabla_{\lambda}\xi^{\mu}##
Similar arguments hold for Lie derivatives of general tensor fields.
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
