Is the limit vector $x$ in the subspace $F$?
In summary, the conversation discusses showing that the subspace F, consisting of sequences whose first coordinate is zero, is closed. This is done by showing that a convergent sequence in F converges to a sequence whose first coordinate is also zero. The concept of coordinatewise convergence is introduced and it is explained that $L^2$-convergence implies coordinatewise convergence. The conversation ends with a clarification on the use of subscripts and superscripts in the notation.
Poirot1
245
Let L^2 be the usual vector space of complex sequences.
Let F be the subspace of sequences whose first term is zero. Show that F is closed.
Let $((V_{nk}):k=1,2,...)$ be a convergent sequence in F. I need to show it converges to a sequence whose first term is 0. Well, for all positive integers n, we have $V_{nk}->x_{n}$ as k tends to infinity. In particular, $V_{n1}->x_{1}$, so I need to show x_{1}=0. Problem is, I don't see why this should be true. I know $V_{11}=1$ but individual terms are of no consequence in the convergence of a sequence.
$L^2$-convergence implies coordinatewise convergence. The reason is that $\|x\|^2 = \sum |x_n|^2$, and it follows that if $\|x\|<\varepsilon$ then $|x_n|<\varepsilon$ for all $n$.
can you please elucidate on what you mean by co-ordinate wise convergence?
Are you saying that if I let $(x_{n})=((V_{n_{k}}):\{k=1,2...\})$ and $(y_{k})$ the limit, we have $||x_{n}-y_{n}||^2= \sum |x_{k}-y{k}|^2$ These subscripts are rather confusing.
Are you saying that if I let $(x_{n})=((V_{nk}:k=1,2...)$ and $(y_{k})$ the limit, we have $||x_{n}-y_{n}||^2= \sum |x_{k}-y{k}|^2$ These subscripts are rather confusing.
Maybe the subscripts will be less confusing if we make one of them a superscript. Suppose you write your sequence as $\{V_n^{(k)}:k=1,2,\ldots\}$, so that $V_n^{(k)}$ means the $n$th coordinate of the $k$th vector.
The question says that $F$ is "the subspace of sequences whose first term is zero." That is a very misleading form of words. I am quite sure that it does not mean that the first member of the sequence is the zero vector. What it should say is that $F$ is the subspace consisting of all sequences whose first coordinate is zero. In other words, it is not saying that $V^{(1)}_n = 0$ for all $n$, but that $V^{(k)}_1 = 0$ for all $k$.
My previous hint was intended to say that if $V^{(k)}\to x$ in $L^2$ (as $k\to \infty$) then $V^{(k)}_n\to x_n$ (as $k\to \infty$) for each $n$ (and in particular for $n=1$).
It seems you have confused my n and k. I was using them in the opposite roles to which you have given them. So I need to show $x_{1}=0$. So I need to show convergence in the complex numbers?
In your initial post, you wrote "$V_{nk}\to x_{n}$ as k tends to infinity. In particular, $V_{n1}\to x_{1}$". You need to sort out which of those subscript refers to the vector and which one refers to the coordinate. There is only one vector $x$, so when you wrote $x_n$ I assumed that you meant $n$ to refer to the coordinate. But the statement "$V_{n1}\to x_{1}$" looks very confused to me, because the $k$ in $V_{nk}$ has become a $1$, whereas the $n$ in $x_n$ has become a $1$. If $k$ is tending to infinity then the $n$ should stay as an $n$, not become a $1$. That is why I suggested making one of the subscripts into a superscript. That would help you to keep the two suffixes from becoming confused.
Ok I will say it in words to help us both. We have a sequence of sequences, tending to a sequence, say x. I posited (and I think you backed this up) that the 'first' sequence tends to to the first term of x. To show x is in F, I need to show that the first term of x is 0; i.e the first sequence tends to 0 in the complex numbers. Beyond that I am stuck. Thanks for your patience
We're still not getting very far with this. I'll have one more attempt to clear up the confusion, and if that doesn't work I'll have to leave it to someone else.
Ok, let's try saying it in words. We have a sequence of vectors. Each vector consists of a sequence of coordinates. The vectors are tending to a limit vector, say $x$. That implies that the first coordinates of the vectors tend to the first coordinate of $x$. Each vector in the sequence is in $F$. That means that the first coordinate of each vector is $0$. But a sequence of $0$s tends to $0$. Therefore the first coordinate of $x$ is $0$ and hence $x$ is in $F$.
FAQ: Is the limit vector $x$ in the subspace $F$?
What does it mean for a subspace to be closed?
For a subspace to be closed, it means that it contains all of its limit points. In other words, every convergent sequence within the subspace must also converge to a point within the subspace.
How do you prove that a subspace is closed?
To prove that a subspace is closed, you can use the sequential criterion for closure. This means showing that every convergent sequence within the subspace converges to a point within the subspace. Another method is to show that the complement of the subspace is open.
Can a subspace be both open and closed?
No, a subspace cannot be both open and closed. This is because if a subspace is open, its complement must be closed. Similarly, if a subspace is closed, its complement must be open. Therefore, a subspace cannot have both open and closed properties at the same time.
What is the relationship between closure and continuity?
The concept of closure is closely related to continuity. In fact, a function is continuous if and only if the inverse image of every closed set is closed. This means that the preimage of a closed subspace under a continuous function will also be a closed subspace.
How is the closure of a subspace related to its span?
The closure of a subspace is the smallest closed subspace that contains it. Therefore, the closure of a subspace is the same as its span. In other words, the span of a subspace is the set of all linear combinations of vectors within the subspace, which is also the closure of the subspace.
