MHB Is the Matrix Positive Definite?
  • Thread starter Thread starter evinda
    Matrix Positive
The discussion centers on proving the positive definiteness of a specific matrix related to a differential equation. The matrix is expressed as a sum of a diagonal matrix and a tridiagonal matrix, with the latter being shown to be positive definite through its relationship with another matrix. The participants confirm that the diagonal matrix is also positive definite due to the positivity of the function q(x). The conversation emphasizes the importance of terminology, clarifying that the correct term is "positive definite." Ultimately, the participants reach a consensus on the validity of their methods and findings.
evinda
MHB
Hello! (Wave)
We have that $q(x) \geq q_0>0, x \in [0,1], h>0$.
Suppose that we have this $(N+1) \times (N+1) matrix$:
$\begin{bmatrix}
\frac{1}{h^2}+\frac{1}{h}+\frac{q(x_0)}{2} & -\frac{1}{h^2} & 0 & \cdots & 0 \\
-\frac{1}{h^2} & \frac{2}{h^2}+q(x_1) & -\frac{1}{h^2} & \cdots &0 \\
0 & & & & \\
0 & & 0 & -\frac{1}{h^2} &\frac{2}{h^2}+q(x_N)
\end{bmatrix}$
I want to show that it is invertible.
I thought to write it as $Q+T$, where $Q=diag (\frac{1}{2}q(x_0),q(x_1), \dots, q(x_N))$ and
$$T=\begin{bmatrix}
\frac{1}{h^2}+\frac{1}{h} & -\frac{1}{h^2} & 0 & & 0\\
-\frac{1}{h^2} & \frac{2}{h^2} & -\frac{1}{h^2}& &0 \\
0 & -\frac{1}{h^2} & \frac{2}{h^2} & & \\
& & & & -\frac{1}{h^2}\\
& & & -\frac{1}{h^2} & \frac{2}{h^2}
\end{bmatrix}$$But how can we show that $T$ is positive defined?
I have found that $x^T T x=\frac{x_0^2}{2}+\frac{1}{h^2} \sum_{i=0}^{N-1} (x_i-x_{i+1})^2+ \frac{x_N^2}{h^2}$. Is it right? (Thinking)
evinda said:
Hello! (Wave)
Suppose that we have this $(N+1) \times (N+1)$ matrix:
$\begin{bmatrix}
0 & & & & \\
\end{bmatrix}$
$$T=\begin{bmatrix}
For convenience, I'll write $a = 1/h$. Let $S$ be the $(N+1) \times (N+1)$ matrix with $a$'s all down the main diagonal, $-a$'s all down the first super-diagonal, and zeros everywhere else: $$S = \begin{bmatrix}
a & -a & 0 & & 0\\ 0 & a & -a & &0 \\ 0 & 0 & a & & \\ & & & \ddots & -a\\ & & & 0 & a \end{bmatrix}.$$ You can check that $$S^{\textsf{T}}S = \begin{bmatrix}a^2 & -a^2 & 0 & & & 0\\ -a^2 & 2a^2 & -a^2 & & &0 \\ 0 & -a^2 & 2a^2 & & & \\ &&& \ddots && \\ & & & & 2a^2& -a^2\\ & & & & -a^2 & 2a^2 \end{bmatrix}.$$ That is a positive definite matrix. It is almost the same as your matrix $T$, which you can obtain by adding $a$ to the element in the top left corner of $S^{\textsf{T}}S$. That will preserve the positive-definiteness (alternatively you could add $a$ to the first element of the diagonal matrix $Q$). This shows that $T$ is positive definite.
Is the way I did it wrong? (Thinking)
Your method is fine. I had not noticed that you already found a solution.
Great! And $Q$ is positive defined since $x^T Q x=\frac{q(x_0)}{2} x_0^2+q(x_1) x_1^2+ \dots+ q(x_N) x_N^2>0$ for $x \neq \overline{0}$ where $x \in R^{N+1}$, right? (Thinking)
Yes! (Star)
Linguistic note: the name for such a matrix is "positive definite", not "positive defined".
Opalg said:
Yes! (Star)
Great! Thank you! (Smirk)
A ok... (Nod)
  • · Replies 26 ·
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 0 ·
