Is the Moody Chart valid for non-Newtonian fluids?
  • Thread starter ccrook
  • Tags
    Fluids
In summary, the Moody Chart is a graphical representation of fluid flow friction factor used to determine head loss and pressure drop in pipes. It can also account for non-Newtonian fluids by using a generalized Reynolds number. However, there are limitations to its accuracy for non-Newtonian fluids due to assumptions and data from experiments with Newtonian fluids. It is recommended to validate results with experimental data or other methods of analysis.
ccrook
I'm pretty sure back in the 1950's there were methods developed for extending this to "purely viscous non-Newtonian fluids," such as power law fluids.
FAQ: Is the Moody Chart valid for non-Newtonian fluids?
What is the Moody Chart and what is its purpose?
The Moody Chart is a graphical representation of the friction factor for fluid flow in a pipe. Its purpose is to determine the head loss and pressure drop in a pipe, which is important in designing and analyzing fluid systems.
Is the Moody Chart only valid for Newtonian fluids?
No, the Moody Chart is also valid for non-Newtonian fluids. However, the friction factor for non-Newtonian fluids may vary depending on the type and behavior of the fluid.
How does the Moody Chart account for non-Newtonian fluids?
The Moody Chart uses a generalized Reynolds number, which takes into account both the viscosity and density of the fluid. This allows for the inclusion of non-Newtonian fluids, which have a variable viscosity.
Are there any limitations to using the Moody Chart for non-Newtonian fluids?
Yes, there are some limitations. The Moody Chart assumes that the fluid is incompressible, which may not always be the case for non-Newtonian fluids. Additionally, the chart is based on data from experiments with Newtonian fluids, so the accuracy may vary for non-Newtonian fluids.
How accurate is the Moody Chart for non-Newtonian fluids?
The accuracy of the Moody Chart for non-Newtonian fluids depends on the specific fluid and its behavior. In general, the chart can provide a good estimate, but it is always recommended to validate the results with experimental data or other methods of analysis.
