MHB Is the perimeter of a right triangle equal to its area? (Part 2)
In the discussion, a right triangle is defined with legs u and v, and hypotenuse w. The values of u, v, and w are expressed in terms of variables m and n. The objective is to demonstrate that the area of the triangle, calculated as (1/2)(uv), equals the perimeter, represented by u + v + w. The participants confirm that the calculations involve multiplying u and v by 1/2 and then adding the lengths to verify the equality. The exercise aims to illustrate that the perimeter and area of this specific right triangle are numerically equal.
mathdad
A right triangle is given. One leg is u units and the other leg is v units. The hypotenuse is given to be w units.
If u = [2(m + n)]/n, v = 4m/(m - n), and
w = [2(m^2 + n^2)/(m - n)n, show that
(1/2)(uv) = u + v + w
I must multiply u times v times (1/2), right? I then must add u + v + w. The right side must equal the left, right?
This exercise will show that the perimeter is numerically equal to the area.
Mathematics news on Phys.org
Yes.
Evgeny.Makarov said:
Yes.
Cool.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
