Dario56
- 290
- 48
In a simple circuit consisting of a battery and a resistor, current will flow if the circuit is closed. Resistor uses the energy provided by the battery, creating heat with a power ##P = UI##, where ##U## is a voltage across the resistor and ##I## is a current through the resistor.
In my classical physics classes, I learned that resistors create heat because of collisions between free electrons and atoms in the crystal lattice of the conductor. Electrons accelerated by the electric field in the conductor, dissipate their kinetic energy as heat. However, in the Science Asylum video on YouTube: Circuit Energy doesn't FLOW the way you THINK!, it was argued that the energy provided to the electrons by the electric field isn't the energy that powers the circuit components, but rather that the fields around the circuit power them. This is explained with the Poynting vector field around the circuit where it is clear that the energy flows from the battery to the resistor.
While that makes sense, it doesn't really explain the mechanism by which the heat is created, it just explains the direction of energy flow and how it relates to electric and magnetic fields. Furthermore, it seems that this explanation is misleading as heat on the resistor can't be magically created by the fields around the circuit, flow of electrons and their interaction with the lattice is a crucial part of how the heat is created on the resistor (if my understanding is correct). Without this interaction, resistor wouldn't create heat, but some other form of energy. Therefore, acceleration of electrons in the electric field is important and it does power the resistor (in the classical view). Also, in the Poynting vector field, it can be seen that inside the conductor, energy flow goes from the outside towards the conductor which I think essentially describes the acceleration of electrons in the electric field.
In another example, LED creates energy in the form of light with much less heat because the mechanism of its operation is quite different compared to the resistor (classical light bulb).
Poynting vector field is very similar in both cases and in both cases, energy flows from the battery to the circuit element. However, Poynting vector by itself can't explain what energy form is created by the circuit element (its different with the resistor and the LED), that has to do with its operation principle.
What are your thoughts?
