MHB Is the Space of Real Polynomials of Degree ≤ n a Euclidean Space?
Sudharaka
MHB
Hi everyone, :)
Here's a question I encountered and I need your help to solve it.
Question:
Let \(V\) be the space of real polynomials of degree \(\leq n\).
a) Check that setting \(\left(f(x),\,g(x)\right)=\int_{0}^{1}f(x)g(x)\,dx\) turns \(V\) to a Euclidean space.
b) If \(n=1\), find the distance from \(f(x)=1\) to the linear span \(U=<x>\).
My Answer:
In our notes it's given that an Euclidean space is a pair \((V,\,f)\) where \(V\) is a vector space over \(\mathbb{R}\) and \(f:V\times V\rightarrow\mathbb{R}\) is a positive symmetric bilinear function. So therefore I thought that we have to check whether the given bilinear function is positive symmetric. It's clearly symmetric as interchanging \(f\) and \(g\) won't matter. But to make it positive we shall find a condition. Let,
\[f(x)=a_{0}+a_{1}x+\cdots+a_{n}x^{n}\]
\[g(x)=b_{0}+b_{1}x\cdots+b_{n}x^{n}\]
Then,
\[f(x)g(x)=\sum_{k=0}^{n}\left(\sum_{i=0}^{n}a_{i}b_{k-i}\right)x^{k}\]
Hence we have,
\[\left(f(x),\,g(x)\right)=\int_{0}^{1}f(x)g(x)\,dx>0\]
\[\Rightarrow \sum_{k=0}^{n}\left(\sum_{i=0}^{n}a_{i}b_{k-i}\right)\frac{1}{k+1}>0\]
Is this the condition that we have to obtain in order for \(V\) to become an Euclidean space?
Usually, a bilinear function f is positive definite iff f(v,v) is non-negative for all v and f(v,v) > 0 for v not zero. If this is what you meant, your conclusion is certainly true. (Apparently, you think positive means f(u,v) > 0 for all u,v. For this interpretation, your result is clearly false. Furthermore, it's impossible to have such a "positive" bilinear form.)
Hi johng, :)
Thanks much for the reply. Yeah, I see the mistake in my interpretation of positive definite. So it seems that the result should be,
\[\Rightarrow \sum_{k=0}^{n}\left(\sum_{i=0}^{n}a_{i}a_{k-i}\right)\frac{1}{k+1}>0\]
Am I correct? I replaced the \(b\) by \(a\).
For a fixed v, you must show (v,v)>=0 and (v,v)=0 only for v=0. So for your particular scalar product, let g be a polynomial of degree at most n. Then
$$(g,g)=\int_0^1g(x)^2\,dx\geq0$$ since the integral of a non-negative function is non-negative.
Also $$\int_0^1g(x)^2\,dx=0\text{ implies }g\equiv0$$ which is true by the fact that if the integral of a non-negative function is 0, then the function must be identically 0.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
