Chris L T521
MHB
- 915
Thanks again to those that participated in the second round of our POTW! Now, it's time for the third one! (Bigsmile)
This week's problem was proposed by yours truly.
Problem: Let $X_i,\, (i=1,\ldots,n)$ be a (continuous) random variable of the exponential distribution $\text{Exp}(\lambda)$, where it's probability density function (p.d.f.) is defined by
\[f(x) = \left\{\begin{array}{cl}\lambda e^{-\lambda x} & x\geq 0,\,\lambda >0\\ 0 & x<0\end{array}\right.\]
Show that $\sum_{i=1}^n X_i$ is equivalent to a random variable of the Gamma distribution $\Gamma(n,\theta)$, where the p.d.f. of the Gamma distribution is given by
\[f(x) = \left\{\begin{array}{cl}\frac{1}{\theta^n\Gamma(n)}x^{n-1}e^{-x/\theta} & x\geq 0,\,\theta>0,\, n\in\mathbb{Z}^+\\ 0 & x<0\end{array}\right.\]
Here are two hints:
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-(POTW)-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
EDIT: I forgot to mention that each $X_i$ are i.i.d. random variables. If they're not, then the above result doesn't hold (thanks to girdav for pointing this out).
Here are two hints:
If $X$ is a continuous random variable, we define the moment generating function by
\[M_X(t) = E[e^{tX}] = \int_{-\infty}^{\infty}e^{tx}f(x)\,dx\]
where $f(x)$ is the p.d.f. of the random variable $X$. Use the fact that if $\{X_i\}_{i=1}^n$ is a collection of random variables, then
\[M_{\sum_{i=1}^n X_i}(t) = \prod_{i=1}^n M_{X_i}(t)\]
Recall that $\Gamma(x) = \displaystyle\int_0^{\infty}e^{-t}t^{x-1}\,dx$.
