MHB Is the Sum of n^2 Terms in an Arithmetic Sequence Limited to 1?
The discussion centers on whether there is only one arithmetic sequence where the sum of the first n terms equals n^2. The derived formula for the nth term is an = 2n - 1, indicating a unique sequence. The sum of n terms can be expressed as a quadratic polynomial, which must have specific coefficients for the sequence to hold true. The pattern observed shows that the first term is 1, and subsequent terms increase by 2, confirming the uniqueness of the sequence. Thus, there is indeed only one arithmetic sequence that satisfies the condition.
stamenkovoca02
How many different arithmetic sequences have the sum of the first n terms n^2?
solution an= 2n-1.Does that mean there is only one arithmetic sequence?
Mathematics news on Phys.org
If the sum of the first $n$ terms must equal $n^2$ for all $n$, then yes, such sequence is unique. To see why, write the sum of $n$ terms using the first term $a_1$ and the difference $d$. This is going to be a quadratic polynomial. Its leading coefficient has to be equal to 1, and the other two have to be 0.
The first term must be 1. The second term must satisfy 1+ x= 4 so x= 3. The third term must satisfy 4+ x= 9 so x=5. The fourth term must satisfy 9+ x= 16 so x= 7.. The fifth term must satisfy 16+ X= 25 so x=9. Do you see a pattern?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
