Is the Sum of Three Cubes Solved for the Number 33 by a Planetary Supercomputer?
  • MHB
  • Thread starter kaliprasad
  • Tags
    Sum
In summary, the discovery of the solution to "33 as sum of 3 cubes" is significant because it is one of the last remaining numbers in the "sum of three cubes" problem to be solved. The solution was found using a combination of computer algorithms and mathematical techniques, and can be applied to other numbers as well. Solving this problem has implications for areas such as cryptography and number theory, and adds to our understanding of the field of mathematics.
Mathematics news on Phys.org
Additionally, the number 42 was solved just a little bit later.
It's already mentioned in the article you refer to as an Editor's Note.
So a planetary supercomputer solved the problem of the number 42, finally giving meaning to Life, the Universe, and Everything.
FAQ: Is the Sum of Three Cubes Solved for the Number 33 by a Planetary Supercomputer?
What is the significance of the "33 as sum of 3 cubes solved" problem in mathematics?
The "33 as sum of 3 cubes solved" problem is significant because it is one of the oldest and most well-known unsolved problems in mathematics. It has been studied for over 200 years and has been attempted by many famous mathematicians, including Leonhard Euler and Pierre de Fermat.
What is the specific problem being addressed in the "33 as sum of 3 cubes solved" solution?
The specific problem being addressed is finding three integers, a, b, and c, such that a³ + b³ + c³ = 33. This problem is also known as the "sum of three cubes problem."
How was the "33 as sum of 3 cubes solved" problem finally solved?
The "33 as sum of 3 cubes solved" problem was solved by mathematician Andrew Booker in 2019. He used a new algorithm and a powerful computer to find the solution, which was previously thought to be impossible.
Is the solution to the "33 as sum of 3 cubes solved" problem unique?
Yes, the solution to the "33 as sum of 3 cubes solved" problem is unique. This means that there is only one set of three integers that satisfy the equation a³ + b³ + c³ = 33. However, there may be multiple solutions to similar problems, such as finding three cubes that sum to a different number.
What implications does the solution to the "33 as sum of 3 cubes solved" problem have in mathematics?
The solution to the "33 as sum of 3 cubes solved" problem has implications in the field of number theory. It provides insight into the structure of numbers and how they can be expressed as sums of cubes. It also opens up possibilities for solving other unsolved problems in mathematics using similar methods.
