jaumzaum
- 434
- 33
- Homework Statement
- See below
- Relevant Equations
- See below
Hello guys. I am a Physics student and I think one of the questions I had to solve in an admission exam from a certain university is incoherent. Can you help me to understand if it is in fact incoherent or not, and if it needs annulment?
The question is:
Three moles of a certain ideal gas, whose molar heat at constant pressure is 5.00 cal / mol.K, is inside the cylinder in the figure below. The gas receives heat from a thermal source (not shown in the figure) in such a way that its temperature increases by 10.0 ° C. When absorbing heat, it is verified that the piston, adiabatic and of negligible mass, rises 2.00 meters. On the piston we have block 1 of mass m1 = 20.0 kg. Consider: g= 10 m/ s ^2 and 1.00 cal = 4.18 J.
a) Calculate the change in the internal energy (in joules) of the gas. (4 points)
b) At the end of the gas expansion, block 1 at rest on the horizontal surface AB, with negligible friction, is reached by block 2 with mass m2 = 10.0 kg and speed equal to 5.00 m / s. Calculate the recoil speed of block 2, knowing that the restitution coefficient is 0.800. (7 points)
I am concerned only with letter A.
Why I think it's wrong?
The question says the cylinder is adiabatic. I will also assume that the process ais reversible and that the transformation inside the cylinder is isobaric. If P is the pressure inside the cylinder:
$$W = P \Delta V = n R \Delta T = 3 \cdot 8,31 \cdot 10=249,3 J$$
$$Q = n C_P \Delta T = 3 \cdot 5 \cdot 4,18 \cdot 10 = 627 J$$
$$\Delta U = Q-W \approx 378 J$$
$$\gamma = Q/\Delta U \approx 5/3 $$
Typical of any monoatomic gas.
However, the work is also:
$$W=P \Delta V = (P_{atm } + mg/A) \Delta V = P_{atm} \Delta V + mgH = P_{atm} \Delta V + 400 = 249,3 J$$
$$P_{atm} \Delta V = -151,7 J$$
So this makes the question impossible, as we cannot have negative atmosferic pressure. The question didn't give the value of R either, nor the value of Pa. If we consider the process is not reversible, is it still possible that this would still be valid? I am not seeing any way this could be true.Can you guys help me? Thank you very much!
The question is:
