Is the time average of a sin function = 0?
In summary, the question is whether the time-average of the interaction between a classical charged particle and a potential of the form V(t) = V Sin(wt) will be zero. The answer depends on the time interval over which the function is averaged. If the interval is [0, infinity), the average is not well defined. However, if the interval is a full period, the average can be calculated using the definition of average. For a function cos(w*t) and a time interval of [-infinity, t], the average is not well defined.
ani4physics
29
Hello all. I just have a simple question. Suppose a classical charged particle is interacting with a potential of the form V(t) = V Sin(wt). The interaction energy is qV(t). My question is, will the time-average of this interaction be zero? Could someone please show me an equation of how to get that time-average. Thanks a lot.
The average of a function on the range [a,b] is
[tex]\bar{f} = \frac{1}{b-a}\int_a^b dt f(t)[/tex]
So, to answer this question, you have to specify the time interval over which you want to average the function. Do you want to average it over a full period? Or from t = 0 to infinity?
For the case of sin(w*t), the [0,infinity) interval doesn't give a well defined average. The full period interval does, and from the definition you should be able to see if it is zero or not.
what if the function is cos(w*t) and the time time interval is [- infinity, t]. does it have a well defined average? thanks very much.
Not really. To do an average where the time tends to infinity generally the integrand must tend to some finite limit there, which cos and sine do not. The integral is then defined on a finite range of integration where the "infinite" endpoint is taken to infinity as a limit. For your particular question this would look like
[tex]\bar{f} = \lim_{T \rightarrow \infty} \frac{1}{t+T}\int_{-T}^t dt \cos(\omega t)[/tex]
which won't be well defined as [itex]T \rightarrow \infty[/itex]. (However, it may be defined in the sense of a distribution such as the dirac delta function).
Similar statements hold for sin(wt).
Maybe I'm making a silly mistake, but I'm pretty sure that, as a pointwise limit of bivariate functions, it converges to
[tex]f(\omega, t) = \begin{cases} 1 & \omega = 0 \\ 0 & \omega \neq 0\end{cases}[/tex]
FAQ: Is the time average of a sin function = 0?
1) Is the time average of a sin function always equal to 0?
No, the time average of a sin function is not always equal to 0. It is only equal to 0 if the function is symmetric about the x-axis and the positive and negative areas cancel out.
2) How do you calculate the time average of a sin function?
The time average of a sin function can be calculated by finding the area under the curve and dividing it by the length of the interval.
3) Can the time average of a sin function ever be negative?
Yes, the time average of a sin function can be negative if the function is not symmetric about the x-axis and the negative areas outweigh the positive areas.
4) Why is the time average of a sin function important?
The time average of a sin function is important because it represents the average value of the function over a given interval, which can be useful in applications such as signal processing and engineering.
5) Does the amplitude or frequency of a sin function affect its time average?
No, the amplitude and frequency of a sin function do not affect its time average. Only the shape of the function and its symmetry about the x-axis determine the time average.
