Is the total amount of gravity in the Universe conserved?
In summary, the theorem can be used to calculate the general curvature of a spacetime, but it does not always apply to pseudo-Riemannian manifolds and the manifold must be compact.
a dull boy
40
In thinking about force symmetry and conservation laws, I think I am right that the total amount of color charge and electric charge in the Universe is conserved, but is gravity conserved? does a Universe at maximum entropy have the same gravity as one say, just after the big bang?
Thanks, Mark
Space news on Phys.org
What do you mean by "amount of gravity"? Without specifying this, your question cannot be answered.
you mean the total mass? I suggest to reformulate the question...
Is gravity conserved in the way that mass-energy is conserved? Did the early Universe have the same amount of gravity as it does today?
I am swimming in deep water here, but isn't it possible to define some notion of "gravity conservation" by considering the topological invariants of the spacetime in question ? In particular I am thinking of the ( generalised ) Gauss-Bonnet theorem here, which connects a measure of total curvature with the Euler characteristic of the manifold; the latter being a topological invariant means that there is a constraint as to how curvature can evolve over time. If you start with a particular gravitational set-up, then it is certainly possible to distort the spacetime manifold in various ways, but you can do so only in a manner that preserves the Euler characteristic.
In that sense, could one not define some concept of "total curvature" ( in the context of GR ) that is in fact a conserved quantity ? This is easily visualised by taking a sphere - you can twist, distort and deform that sphere in any which way you want, but no matter what you do, you will never be able to deform it into a flat plane, i.e. you will never be able to completely eliminate the curvature that was intrinsic to the manifold when you started. The same should be true for gravity - you cannot locally "eliminate" it, the most you can do is spread it out as gravitational radiation.
AFAIK this theorem only applies to Riemannian manifolds, not pseudo-Riemannian, so it would not apply to spacetime.
You are right, I overlooked that :oops: However, it seems that the theorem can be extended to cover pseudo-Riemannian manifolds as well, so long as they are orientable :
https://duetosymmetry.com/files/An. Acad. Brasil. Ci. 1963 Chern.pdf
Thanks for the link, interesting!
However, there is also another key restriction on the theorem, which also appears to apply to the pseudo-Riemannian version: the manifold must be compact. Unfortunately, that is not true of any spacetime of physical interest that I'm aware of. The closest possibility would be a closed FRW universe, for which each spacelike slice of constant comoving time is compact; but even there the spacetime as a whole, as a 4-d manifold, is not compact. So unfortunately I don't think there is any way to use this theorem in the way you're proposing.
Good point @PeterDonis, I overlooked that as well o_O
That's what happens when an amateur's enthusiasm for the subject outpaces his limited knowledge !
FAQ: Is the total amount of gravity in the Universe conserved?
What is the concept of conservation of gravity in the Universe?
The concept of conservation of gravity states that the total amount of gravity in the Universe remains constant and cannot be created or destroyed. This means that the total gravitational force exerted by all objects in the Universe remains the same over time.
How can we measure the total amount of gravity in the Universe?
The total amount of gravity in the Universe can be measured by studying the distribution of mass and energy in the Universe. Scientists use various methods such as gravitational lensing, cosmic microwave background radiation, and galaxy rotation curves to estimate the total gravitational force exerted by all objects in the Universe.
Is the conservation of gravity a proven theory?
Yes, the conservation of gravity is a well-established theory that is supported by numerous observations and experiments. It is a fundamental principle in physics and is included in theories such as general relativity and Newton's law of universal gravitation.
Can the total amount of gravity in the Universe change over time?
No, according to the principle of conservation of gravity, the total amount of gravity in the Universe cannot change over time. While the distribution of mass and energy in the Universe may change, the total gravitational force remains constant.
How does the conservation of gravity impact the evolution of the Universe?
The conservation of gravity plays a crucial role in the evolution of the Universe. It helps to maintain the stability of the Universe and influences the formation of galaxies, stars, and other celestial bodies. Without the conservation of gravity, the Universe would not be able to sustain its current structure and may have evolved in a completely different way.
