Is the total electric field of two opposite charges 0?
In summary, the electric field of two particles with opposite charges of the same magnitude will not cancel out each other completely unless they are located at the same point. In general, the field at any point will be the vector sum of the individual fields from each charge. The electric field will only be zero if the two charges merge into a single charge. Therefore, the electric field will not be zero if the charges are located at different points.
Blockade
68
Let's say you have two particles that are the same in magnitude but have opposite charges like the equation down below:
E1 = -q*k/r^2
E2 = q*k/r^2
ETotal = q*k/r^2 + -q*k/r^2 = 0
Does this mean that the electric field of both these charges cancel out each other? Then what is the electric field if they ever come into contact since opposite attracts?
Only if the two charges are right on top of each other. In general, the field at any point will be the vector sum of the fields from each charge.
So it's like the picture down below where at any point (position) in that picture the electric field = 0 just as long as those two charges are either 0, 90, 180, and 270 degrees from each other? Anything that does not make their magnitude different from one another. In that case 45 degrees, the magnitude and the Electric field will be 0 as well? As a result, the negative charge can is all to pull all the electric field that the positive charge has to give out?
I don't understand what you mean by "0, 90, 180, and 270 degrees from each other". Where do you think the field is zero?
The field at a distance of one single charge will be reduced by the presence of a second, opposite charge. (An Electric Dipole).
The cancellation is never complete but the field will drop off quicker than the Inverse Square Law for a single charge. See this link.
I think that the electric field is zero everywhere within the bottom picture since they share the same axis.
proxy.php?image=http%3A%2F%2Fwww.physics.udel.edu%2F%7Ewatson%2Fphys208%2Fimages%2Ftip18-18a.gif
The electric field at any point is the vector sum of the fields from the two charges. See this diagram for an example:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/mulpoi.html#c2
This example is for two positive charges, not for one positive and one negative. However, if you make one of the charges negative, you simply "flip" its electric field vector around the point in question so it points in the opposite direction (directly towards the negative charge). This changes the resultant (total) electric field vector, but does not make it zero.
For your situation, two charges that are equal in magnitude but opposite in sign, there is no point where the total electric field is zero.
Likes CWatters
It is not. In fact, the red arrows indicate the direction of the electric field at each point in the diagram, and there is nowhere where it is zero.
It would be a good exercise to try calculating the field at a few points, just to see how it never comes out zero. You can do this for points on the line through the two charges with just elementary arithmetic; you'll need some trigonometry to do it for points off that line.
Realize that the two charges would 'share the same axis' no matter where they are. (You'd just rotate the diagram as needed.)
Please read the posts above (by jtbell and Nugatory) to understand why the field is not zero anywhere.
If the charges were the same then there would be one point where the field is zero.
If they merge, the resulting charge and thus the field is zero. Otherwise see the other answers.
You have to be careful when using equations. In particular, how are you defining "r?" If it's the distance from the first charge (located therefore at the origin where r=0), then you can't use the second equation unless the second charge is also at the origin.
Likes sophiecentaur
FAQ: Is the total electric field of two opposite charges 0?
1. What is the concept of "total electric field"?
The total electric field refers to the combined effect of electric fields from multiple charges in a given area. It is the vector sum of all individual electric fields.
2. Why would the total electric field of two opposite charges be 0?
This occurs when the two charges have equal magnitudes but opposite signs, resulting in the cancellation of their electric fields.
3. Is the total electric field of two opposite charges always 0?
No, it is not always 0. The total electric field depends on the distance between the two charges and the magnitude of each charge.
4. How does the distance between two opposite charges affect the total electric field?
The closer the charges are, the stronger the electric field will be. As the distance between them increases, the electric field will decrease.
5. Can the total electric field of two opposite charges ever be greater than 0?
Yes, it is possible for the total electric field to be greater than 0 if the magnitudes of the two charges are not equal.
