Is the Universe a 3-sphere or a 4-sphere?
  • I
  • Thread starter Herbascious J
  • Tags
    Universe
In summary, when discussing the shape of the universe, presenters often use a 2-D analogy of how a flat sheet can be curved or shaped, like a saddle, table, or surface of a ball, where triangles can be defined with different sums to their angles. This analogy makes perfect sense to me. However, when thinking of the 4-D space-time geometry, most discussions implicitly split up the dimensions into 3 of space and one of time in a particular way.
  • #36
PeterDonis said:
No.
Ok suppose the black hole has an event horizon radius equal to the present observable universe radius. The receiver has at least escape velocity directly away from the center of the singularity at a distance from the center of 2 event horizon radii. The sender is 1 billion light years directly “above” the receiver with respect to the singularity. Assume in the scenario “spatial expansion” = 0 and at transmission time the sender is approaching the receiver. At the same time as the pulse is received, the sender is also approaching the receiver. There are no other gravitational bodies than the singularity and the 2 craft, and neither craft detects acceleration or fictitious forces. Can the receiver detect redshift from a pre-agreed frequency?
Space news on Phys.org
  • #37
It depends on how fast the sender is approaching the receiver when the pulse is sent, as compared to the difference in height between them.
  • #38
So if it’s “possible” then to detect redshift from a distant approaching object when both the observer and object have at least escape velocity from a large singularity which is outside their observable universe, and the equations describing this redshift are already known, why is “spatial expansion” via an “unknown” mechanism considered a “more likely” explanation for the observation of red shifts which vary in proportion to distance from an observer?
  • #39
First, the mechanism is not unknown; it's just inertia from the Big Bang.
Second, as has already been pointed out, redshifts in your scenario would not be isotropic. But we observe them to be isotropic.
  • #40
All versions of your scenario imply an overall "upwards" and a "downwards" direction to the observable universe, with different redshift-versus-distance profiles if you look "up" or "down". We don't see that - once you correct for our velocity compared to a comoving observer the redshift profiles are the same in all directions - isotropic, as PeterDonis says.
Likes sysprog
  • #41
^If a formation of transmitter spaceships all at rest with respect to the receiver (also comoving, assume spatial expansion = 0) at transmission time were all traveling close enough to light speed directly away from the singularity in the scenario (each separated by either 1b or 2b ly from receiver at transmission time - some higher, some lower, some same height above singularity as receiver), I thought that most light emitted by these ships, even light emitted in a very “downward” direction from their rest frame, would actually end up traveling in a very “upward” direction with respect to the singularity, and become redshifted due to the relativistic aberration... Is this correct? I thought with increasing separation between craft, the light must climb higher out of the singularity’s gravity well in transit between craft and thus the pulses become more redshifted with increasing separation distance . In other words, with enough velocity away from the singularity can relativistic aberration redirect nearly all light emitted by the craft away from the singularity and thus produce redshift from all directions in the receiver’s relativistic rest frame with respect to the singularity?
  • #42
No.
  • #43
The OP question has been answered, and the current subthread is verging on personal speculation. Thread closed.
  • Cosmology
  • Cosmology
  • Cosmology
