Is the universe expanding faster than expected
In summary, there is a discrepancy between the Hubble Constant values measured from the Cosmic Microwave Background (CMB) data and those measured in the local universe, with the latter giving higher values. This could be due to missing physics in the current model or systematic errors in measurements. The method used in the study, which relies on geometry and General Relativity, may not be as accurate as claimed since it does not account for factors such as the low density plasma in the intervening space. Such discrepancies are often resolved by more careful analysis of systematic errors, but sometimes they can lead to new physics.
wolram
Dearly Missed
4,446
558
I can not find a paper on this, but is it possible that the universe is expanding faster than expected?
https://www.sciencedaily.com/releases/2017/01/170126132624.htm
Because galaxies do not create perfectly spherical distortions in the fabric of space and the lensing galaxies and quasars are not perfectly aligned, the light from the different images of the background quasar follows paths which have slightly different lengths. Since the brightness of quasars changes over time, astronomers can see the different images flicker at different times, the delays between them depending on the lengths of the paths the light has taken. These delays are directly related to the value of the Hubble constant. "Our method is the most simple and direct way to measure the Hubble constant as it only uses geometry and General Relativity, no other assumptions," explains co-lead Frédéric Courbin from EPFL , Switzerland.
Likes Buzz Bloom
Astronomy news on Phys.org
It's clear there is a discrepancy between the Hubble Constant value that best fits the CMB data (the 66.93±0.62 referred to in the article from the Planck satellite) and the Hubble Constant value measured in the local universe by other methods, which gives higher values more like 71 or 72 km/sec/Mpc. Whether the discrepancy reflects new physics which is missing from the Lambda-CDM model or whether it reflects systematic errors in the measurements is anybody's guess at this point.
Likes Buzz Bloom
Thank you physguy, I thought using General relativity, and geometry would be an accurate method. May be it is not as accurate as they say.
phyzguy said:
It's clear there is a discrepancy between the Hubble Constant value that best fits the CMB data (the 66.93±0.62 referred to in the article from the Planck satellite) and the Hubble Constant value measured in the local universe by other methods, which gives higher values more like 71 or 72 km/sec/Mpc. Whether the discrepancy reflects new physics which is missing from the Lambda-CDM model of whether it reflects systematic errors in the measurements is anybody's guess at this point.
The discrepancy between 67 and 71 is only about 5%. When you start getting down to small errors like this, many small effects start to matter. For example, the article says, "it only uses geometry and General Relativity, no other assumptions,". But what about the fact that the intervening space between us and these galaxies is not empty? It contains a low density plasma which affects the light travel time. I'm not saying this is the explanation, I'm just saying that when you get down to the few percent level, it is easy to miss some small effects. Historically these types of discrepancies are usually not resolved through revolutionary new physics, they are resolved by more careful analysis of the systematic errors. Sometimes, however, they do result in new physics. Time will tell.
Likes wolram
Thank you phyzguy.
Related to Is the universe expanding faster than expected
1. What evidence suggests that the universe is expanding faster than expected?
The most compelling evidence comes from observations of distant supernovae and the cosmic microwave background radiation. These observations show that the expansion of the universe is accelerating, which indicates that the universe is expanding faster than previously thought.
2. What is causing the universe to expand faster than expected?
The cause of this accelerated expansion is currently believed to be dark energy, a mysterious force that makes up about 70% of the total energy in the universe. This force is thought to counteract the gravitational pull of matter, causing the universe to expand at an increasing rate.
3. How does this discovery impact our understanding of the universe?
The discovery of the universe's accelerated expansion has major implications for our understanding of the universe. It challenges our current models and theories, and raises questions about the nature of dark energy and the fate of the universe.
4. Could the universe eventually stop expanding and start contracting?
Based on current observations, it is unlikely that the universe will stop expanding and start contracting. The accelerating expansion indicates that the universe will continue to expand indefinitely, and it is unlikely that the expansion will ever reverse.
5. Could this discovery change our understanding of time and space?
Yes, the discovery of accelerated expansion has already led to revisions in our understanding of time and space. It has also opened up new avenues for research and exploration, as scientists try to understand the nature of dark energy and its role in the expansion of the universe.
  • Astronomy and Astrophysics
  • Quantum Interpretations and Foundations
  • Cosmology
