Is the universe expanding or it is circuiting?
In summary: PIn summary, the conversation discusses the concept of a rotating 4D tesseract as a potential model for the universe and the role of time as a dimension. The conversation also touches on the reasons for the rotation of planets and stars, the expanding universe and theories such as string theory and the multiverse.
Neghentropia
ok, here it goes:
this afternoon, wandering on wikipedia I stumbled across a 3D projection of a rotating tesseract
I spent some time looking at it, then i started thinking about the universe.
a bit of context: I've always been passionate for astronomy. I like to read about other planets and stars, and I find amusing to know facts about extraterrestrial worlds.
I don't really have a working knowledge of physics. I'm a biotechnologist and even though I spent two years studying engineering (well, studying...) I know little about the law of physics. So forgive me if what I'm going to say is either totally insane, common knowledge that any physycist already takes for granted, or not expressed in fluent English, which is not my first language... :-p
there are 3 things I don't "like" about what our universe.
- the fact it's expanding (especially I don't like that it seems to be destined to expand indefinitely...mh...)
- time as we intend it (i.e. non a touchable dimension)
- the fact planets, stars, galaxies and everything out there revolve. why is everything moving in circle?
now, I know time is considered as a 4th dimensions. it bends, it crunches, it dilates, and I even read somewhere it actually IS a proper dimension, only that we perceive it as time (in this context proper dimension stands for dimension of space)
that's why I was fascinated by the rotating tesseract.
because it looks like how I would like our universe to be!
a rotating 4D tesseract.
looking better at the 3D projection I thought that if this was true, for 3D observers as we are a 4D rotating tesseract would appear to be expanding on one side an cruncing on the other (or better...it would appear to expand on half of its sideS and cruch on the other half).
also, any circular motion in our apparent 3D universe would be the "translation" of a straight motion in the "proper" 4D universe.
what I'm trying to say is that I could envision a universe, shaped a bit like a 3D thorus with a ridiculosly small center (the Big Bang) from which the whole univere texture spun out and to which it also crunch in. everything in a straight motion "upon itself" with the time playing the role of a dimension, which starts and finishes at the center of the universe.
in this model (let's call it circuiting universe ) the Big Bang is a continuous event which takes place in that region of the universe where all the matter, after one complete circle, fell down again, crunching in infinitesimally small proportion before being ejected from the other side, ready for another circle, which leght is what we would call "age".
ok, this is by far the biggest amount of nonsens I ever said while sober, but I hope you could enlighten me on the flaws of this idea.
again. no, or very little, scientfic knowledge stands behind this topic so forgive me if this doens't comply with the forum's policy.
cheers :)
Astronomy news on Phys.org
Try to define "touchable" without using "time" and "space" as different things in the definition ;).
In general, every object has some angular momentum, and processes to get rid of that are are. Most objects have to rotate due to angular momentum conservation.
Well, it is different, it has an opposite sign in the metric of spacetime. Very similar in some aspects, but not the same.
The universe does not care about your will ;).
A straight motion in 4D cannot give a rotation in 3D.
Using one spatial dimension to display time is very common in physics, and you can describe the universe as a static 4-dimensional object. That is fine.
But you won't get our universe as a result of a "moving" 4-dimensional object (that would require a 5th dimension for time, by the way).
"Why is everything moving in a circle."
All planets and stars form from the collapse of interstellar clouds of dust (nebulas) which have a certain angular momentum. Planetary systems spin due to the angular momentum of their parent-nebula. (Law of the Conservation of Angular Momentum.)
There are a few theories regarding the expanding universe. One states that that the universe will accelerate indefinitely and the rate of acceleration will increase as time goes by. Dark matter is the energy that is believed to cause the accelerated expansion. Another states that gravity will eventually slow down the acceleration and the universe will then collapse in on itself. (The Big Crunch.)
String theory states that there is no one universe, rather, there is a multiverse. Universes can be formed when a larger universe splits. Likewise, a larger universe can be formed when two smaller universe merge.
References you might find interesting:
String Theory:
Why planets rotate:
http://curious.astro.cornell.edu/question.php?number=416
dammit...
:biggrin:
ok, I got the reason why everything rotates. basically just because if it didn't it wouldn't be like it is (something that reminds me of the anthropological principle...)
mfb, could you clarify why it's OK to consider time as a dimension for a static snapshopt of our universe, but I would need to add a 5th dimension to consider motion?
or is it because the motion itself? I mean, is time a "different" dimension than the other three so to allow the motion of a 3D object?
thanks for the video Absolute0, I did enjoyed it.
I have heard about string theory before and I have to admit the idea of a multiverse is quite tantalizing.
If you want motion (a time-dimension) in a 4-dimensional "space"-space, you get a 5-dimensional spacetime.
Time is a bit different, right.
do you know where I could read more about the difference between space and time?
You can search for websites/books/scrips about special relativity - there are hundreds of them, some are good some are not.
I believe its not expanding -but that its contracting, and ever faster - the same laws and effecvts apply to points that are moving away from each other as to points that are moving towards each other accelerating - as a Point closer towards the centre accelerates away from a point further away and the point further away actually accelerates from a point even further away so red shift also applies - also it makes sense that we are in an imploding mode unlike an ever expanding universe, with matter accelerating ever greater towards the speed of light and in the process the eis being transformed into mass increase which may give answer to the dark matter problem as matter is being created/increased the closer it is accelerated towards the point of conjunction - also it may be that from this point energy/gamma rays or other are then shot out like from a mega black hole thus creating a rotating system of energy to mass transformation and dispersal to the outer limits where it is then formed back into particles/matter and collapses inwardly through gravitational attraction -this would make sense unlike all this ever expanding accelerating universe theory
I think that your model clashes with the evidence that universe is expanding in every direction
it it was actually crushsing down, I imagine we would see it accelerating but we would also see evidence of shrinking somewhere out there
unless the site of the Big-Cruch to be is out of the observable universe
but still...if the universe is "falling" down towards a signle point we should be able to detect a gradient of acceleration toward such a point
No it would not.
You don't get the same observations in every direction with that model (in particular, you would get directions with blueshift), the redshift/distance relation would be different everywhere, you don't get the cosmic microwave background, the correct isotopic composition of the world or anything else.
Related to Is the universe expanding or it is circuiting?
1. Is the universe expanding or is it circling?
The current scientific consensus is that the universe is expanding. This is supported by multiple lines of evidence, such as the redshift of distant galaxies and the cosmic microwave background radiation.
2. How do we know that the universe is expanding?
As mentioned above, there are several pieces of evidence that support the idea of an expanding universe. One of the key pieces of evidence is the observation that distant galaxies appear to be moving away from us at increasing speeds, which suggests that the space between them and us is expanding.
3. What does it mean for the universe to be expanding?
The concept of an expanding universe can be difficult to wrap our minds around, as we are used to thinking of space as static. Essentially, it means that the distance between objects in the universe is increasing over time. This expansion is happening at the largest scales, and is not noticeable on smaller scales, such as within our own solar system.
4. Could the expansion of the universe eventually stop or reverse?
There are various theories about the fate of the universe, but the most widely accepted one is that the expansion will continue indefinitely. This is because the amount of matter and energy in the universe is not enough to counteract the expansion caused by dark energy. However, our understanding of dark energy is still limited, so it's possible that new discoveries could change this theory.
5. How does the expansion of the universe relate to the Big Bang theory?
The Big Bang theory is the prevailing scientific explanation for the origin of the universe. It suggests that the universe began as a singularity and has been expanding ever since. The expansion of the universe is one of the key pieces of evidence that supports the Big Bang theory.
  • Astronomy and Astrophysics
