Is the vacuum stress energy tensor Lorentz invariant ?
In summary: In other words, the vacuum stress-energy tensor must be Lorentz invariant under a Lorentz boost. However, this does not mean that the observed vacuum pressure (minus the vacuum energy density) is equal to the vacuum energy density.
notknowing
185
In many textbooks on relativity, one finds at some point a statement that the vacuum stress energy tensor should be Lorentz invariant, from which it then follows that the vacuum pressure is minus the vacuum energy density.
However, the vacuum energy density (or stress tensor) is not an observable as such, so it is not clear to me why it should be Lorentz invariant. Only when it is included in some physical law, then this law should be Lorentz invariant (or so called covariant). An invariant law does not have to imply the invariance of all its components. Is there a flaw in my reasoning ?
Tensors in general are not invariant but tensor equations are covariant. The equation remains true even though the components of the tensors in it change with viewpoint. So if the vacuum stress energy tensor equals zero in one frame then it equals zero in all frames. Perhaps this is what you read?
Yes, that is indeed what I thought. There seems not to exist a separate equation for the stress-energy tensor of the vacuum(for instance that it is zero). One considers the vacuum to be a fluid with no viscosity, such that it has only diagonal components. And then one insists that this tensor should be invariant under a Lorentz boost. I do not see the reason for this requirement.
Consider two observers coincident at the spacetime event p. Each observer can set up orthonormal set (tetrad) of (tangent) 4-vectors with respect to which the observers make measurements. If the observers are in relative motion, then the two tetrads are different, but even in general relativity, the tetrads are related by a Lorentz transformation.
Now consider an electromagnetic field also present at p. Each observer measures the components of the field with respect to the appropriate tetrad, and components are related in the standard way by Lorentz transformations. This is covariance, not invariance. Also, energies are related in the standard way.
Now consider the vacuum. Lorentz invariance of the vacuum energy-momentum tensor means that the components are the *same* with respect to both (actually, all) tetrads at (every) p. The only second-rank tensor that has the same components with respect to all tetrads is g.
Thanks for this explanation, but I don't see how this justifies why the vacuum energy-momentum tensor must be Lorentz invariant as nobody has the ability to measure and compare its components in different frames.
Yes, I carefully avoided giving a reason. :biggrin:
I think the hope is that someday a theory will predict the values of the components, i.e., the propotionality to g, and that this will correspond to the measured value of the cosmological constant/dark energy.
If we write the stress-energy tensor of the vacuum-with-a-cosmological constant it in cartesian coordinates (t,x,y,z)
[itex]T^{ij}[/itex] = diag(k,-k,-k,-k)
then boost it in the x direction
[tex]T'^{00} = (\Lambda^0{}_0) ^2 T^{00} + (\Lambda^0{}_1)^2 T^{11}[/tex]
[itex]T'^{11} = (\Lambda^1{}_1)^2 T^{11} + (\Lambda^1{}_0)^2 T^{00}
[/tex]
With [itex]\Lambda^0{}_0 = \Lambda^1{}_1 =\gamma [/itex] and [itex]\Lambda^0{}_1 = \Lambda^1{}_0 = -\beta \gamma[/itex]
we get
[tex]T'^{00} = \gamma^2 T^{00} + \beta^2 \gamma^2 T^{11} = \gamma^2 k - \beta^2 \gamma^2 k = k[/tex]
[tex]T'{11} = \gamma^2 T^{11} + \beta^2 \gamma^2 T^{00} = -k \gamma^2 + \beta^2 \gamma^2 k = -k[/tex]
which is the same. Unless I've made a silly sign error somewhere?
Yes, you calculated correctly but it only shows that if rho = - pressure one obtains a Lorentz invariant tensor (or vice versa). So it does not answer why the vacuum energy-stress tensor should be Lorentz invariant in the first place (or should have rho = - p in the first place)
Although vacuum does not mean containing nothing, there should be no preferred coordinate system in a vacuum. But if its stress-energy tensor (T) is not Lorentz-invariant, then there would be one. Therefore, T must be Lorentz-invariant.
It turns out that we have only one choice for such a tensor: the Minkowski metric (up to some constant).
FAQ: Is the vacuum stress energy tensor Lorentz invariant ?
How is the vacuum stress energy tensor defined?
The vacuum stress energy tensor is a mathematical object used in the theory of relativity to describe the distribution of energy and momentum in empty space. It is defined as a symmetric rank-2 tensor that satisfies the conservation law for energy and momentum.
Is the vacuum stress energy tensor Lorentz invariant in all reference frames?
Yes, the vacuum stress energy tensor is Lorentz invariant. This means that its components remain the same regardless of the reference frame from which they are observed. This is a fundamental principle of relativity and is necessary for the consistency of the theory.
What is the physical significance of the vacuum stress energy tensor?
The vacuum stress energy tensor describes the energy and momentum associated with the vacuum of empty space. This may seem counterintuitive, but in the theory of relativity, empty space is not truly empty and can contain energy and momentum due to the presence of quantum fields.
How is the vacuum stress energy tensor related to dark energy?
Dark energy is a mysterious form of energy that is thought to be responsible for the accelerated expansion of the universe. Some theories suggest that dark energy can be described by the vacuum stress energy tensor, but this is still a topic of ongoing research and debate among scientists.
Can the vacuum stress energy tensor be measured experimentally?
Currently, there is no known way to directly measure the vacuum stress energy tensor. However, its effects can be indirectly observed through phenomena such as the Casimir effect and the cosmological constant. Further research and advancements in technology may lead to a better understanding and potential measurement of this tensor in the future.
