Is There a Better Way to Approach Vector Identities?
In summary, the conversation discusses the use of a previous exercise to solve a problem involving vectors and dot products. The expert summarizer provides a step-by-step explanation of how to approach the problem, including the use of a property of the dot product. There is also a correction made for a mistake in the original solution. The conversation ends with a thank you for the help and mentions missing the interaction of a university environment.
ognik
643
Please excuse my copying this question in, minimising my input :-)
Part (b): Let $ a.b \times c =v $
Then $ a'.b' \times c' = \left( \frac{b \times c}{v}\right) . \left( \frac{c \times a}{v} \times \frac{a \times b}{v}\right) $
$ = v^{-1} \left(b \times c\right). \left[ \left(c \times a\right) \times \left(a \times b\right) \right] $
From a previous exercise, $ \left(a \times b\right) \times \left(c \times d\right) = \left(a.b \times d\right)c - \left(a.b \times c\right)d $ ...
I get $ v^{-1} \left(b \times c\right). \left[ \left(c.a \times b\right)a - \left(c.a \times a\right)b \right] $
the $a \times a$ term = 0, but I am not sure of the laws around something like $ \left(c.a \times b\right)a $
I don't think I can do $ \left(c.a.a \times b.a\right) $ ? So I'm a bit stuck here, maybe there's a better way to approach this..
With your definition of $v=\mathbf{a}\cdot(\mathbf{b}\times\mathbf{c})$, we have
\begin{align*}
\mathbf{a}'\cdot(\mathbf{b}'\times\mathbf{c}')&=\frac{1}{v^3}\left[(\mathbf{b}\times\mathbf{c})\cdot
((\mathbf{c}\times\mathbf{a})\times(\mathbf{a}\times\mathbf{b}))\right] \\
[(\mathbf{c}\cdot(\mathbf{a}\times\mathbf{b}))\mathbf{a}-\underbrace{(\mathbf{c}\cdot(\mathbf{a}\times\mathbf{a}))\mathbf{b}}_{=\mathbf{0}}]\right] \\
&=\frac{\mathbf{c}\cdot(\mathbf{b}\times\mathbf{a})}{v^3} \, [(\mathbf{b}\times\mathbf{c})\cdot\mathbf{a}].
\end{align*}
Recognizing that $\mathbf{a}\cdot(\mathbf{b}\times\mathbf{c})=\mathbf{b}\cdot(\mathbf{c}\times\mathbf{a})
=\mathbf{c}\cdot(\mathbf{a}\times\mathbf{b})$, can you finish?
Ackbach said:
$\frac{\mathbf{c}\cdot(\mathbf{b}\times\mathbf{a})}{v^3} \, [(\mathbf{b}\times\mathbf{c})\cdot\mathbf{a}].$
Its this step I am struggling with, can't see what (identity?) gets this from the previous step?
There's a property of the dot product. Suppose $\mathbf{a}$ and $\mathbf{b}$ are vectors, and $c$ is a scalar. Then it is a fact that $\mathbf{a}\cdot(c\mathbf{b})=c(\mathbf{a}\cdot\mathbf{b})$. Then, it's very important to remember that the result of a cross product is a vector, and the result of a dot product is a scalar. It follows that
\begin{align*}
\mathbf{a}'\cdot\left(\mathbf{b}'\times\mathbf{c}'\right)&=\frac{1}{v^3}\left[(\mathbf{b}\times\mathbf{c})\cdot
&=\frac{1}{v^3}\left[\underbrace{(\mathbf{b}\times\mathbf{c})}_{\text{vector}}\cdot
[\underbrace{(\mathbf{c}\cdot(\mathbf{a}\times\mathbf{b}))}_{\text{scalar}} \; \mathbf{a}-\underbrace{(\mathbf{c}\cdot(\mathbf{a}\times\mathbf{a}))\mathbf{b}}_{=\mathbf{0}}]\right] \\
[\underbrace{(\mathbf{c}\cdot(\mathbf{a}\times\mathbf{b}))}_{\text{scalar}} \; \mathbf{a}\right] \\
\end{align*}
Does that answer your question?
[EDIT] See below for a correction.
It did finally, and just checking - in the c.(A x B) did you accidentally swap A x B to B x A ?
You're quite right. It should be $\mathbf{c}\cdot(\mathbf{a}\times\mathbf{b})$ in the last line. Good catch, and thank you!
It feels good to be getting better - and a significant amount of thanks is due to yourself and others who have helped me this year! While I am happy working on my own, I do miss the interaction of a University environment, it makes more of a difference than I expected.
FAQ: Is There a Better Way to Approach Vector Identities?
What are vector identities and why are they important in science?
Vector identities are mathematical relationships or equations that involve vector quantities, such as direction and magnitude. They are important in science because they provide a way to simplify and manipulate complex vector equations, making it easier to solve problems and understand physical phenomena.
Can you give an example of a vector identity?
One example of a vector identity is the cross product identity, which states that the cross product of two vectors is equal to the negative of the cross product of the same vectors in reverse order. This is written as a x (b x c) = (a x b) x c = -b x (a x c).
How are vector identities used in physics?
Vector identities are used extensively in physics to describe and analyze physical quantities, such as force, velocity, and acceleration. They are used to simplify and manipulate equations in mechanics, electromagnetism, and other areas of physics to better understand and predict the behavior of physical systems.
Are there any common mistakes when working with vector identities?
One common mistake when working with vector identities is forgetting to take into account the direction of the vectors. Vectors are not just numerical values, but also have a direction, and this must be considered when applying vector identities. Another mistake is not properly applying the properties of vector operations, such as the commutative and distributive properties, which can lead to incorrect results.
How can I improve my understanding and application of vector identities?
To improve your understanding and application of vector identities, it is important to practice solving problems and working with different types of vector equations. You can also review the properties and rules of vector operations, as well as the geometric interpretations of vector identities. Additionally, seeking help from a tutor or collaborating with other scientists can also enhance your understanding of vector identities.
