- #36
Ken G
- 554
The issue in the OP is, does Newton's first law reference the concept of inertia, or indeed even require such a concept, or does that only show up in the second law? The OPer was making the case, and I agree, that the first law does not reference inertia, which means there is a "common misconception" that inertia is the reason that objects that are in motion will stay in motion if no forces act on them. Instead, when an object has no force on it, then its inertia is irrelevant, since we can simply refer to the first law (even though the second law yields the same conclusion as the first-- that just means the laws are consistent). Inertia is the concept of how much objects accelerate when forces are exerted on them. The first law is merely the assertion of what happens when no forces are exerted, and that is true independently of the inertia or even if there is any inertia. To support that argument, I cite the first law.zoobyshoe said:I have no idea what you're saying or where you're going with this.
Yes, I use it in that same sense-- note especially the part about "in the interest of..."The "law or axiom" is asserted as truth in the interest of getting traction on a problem. It provides a basis for a train of logic in analyzing something.
I see the problem, you are reading something unintended into the word "just." I do not mean that any law is somehow equal, since they are all "just" assertions, I mean that a law is just an assertion. Which is just exactly what a law is-- the point is, if the law doesn't refer to inertia, then the assertion the law is making doesn't either, and it makes not the least bit of difference if the law doesn't apply in some situation (such as in quantum mechanics, or when there is no inertia-- even though this law does apply when there is no inertia, as long as we generalize "force" to "any influence or change in the environment"). I used "just" to stress that the law is what it is, so what it asserts is independent of when it holds, and so in analyzing what a law says, there is no need to wonder about when the law is actually true, or if the law is ever actually true. Note this is consistent with the definition you just gave.The Laws or Axioms are not, therefore, "just" assertions.
