Is There a Connection Between Big 'O' Order Symbols and Limits?
  • MHB
  • Thread starter Poirot1
  • Tags
    Symbols
In summary, the conversation discusses the definition of Big O notation and how it relates to the limit of a function. The participants also address the difference between strictly Big O and 'little' o, and whether a function can tend to a limit as x approaches a. There is also a clarification on the definition of O(f(x))=O(f(x)).
Poirot1
245
I have come across a number of examples in my textbook which seem to suggest that
if f(x)-> L as x-> a, then O(f(x))->L as x->a. Can this be proven?
to clarify, I mean O(f(x))=O(f(x)) as x-> a
Hi Poirot, :)
Yes. This is a direct consequence of the definition of the Big O notation.
Definition: Let \(a\in\Re\) and \(f\) and \(g\) be two functions of \(x\). Then we write,
\[f(x)=O(g(x))\text{ as }x\to a\,\]
if and only if there exist \(\delta,\,M>0\) such that,
\[|f(x)| \le \; M |g(x)|\text{ for }|x - a| < \delta\]
(Reference: Big O notation - Wikipedia, the free encyclopedia)
Now using the above definition we see that,
\[f(x)=O(f(x))\]
Hence if \(f(x)\rightarrow L\) as \(x\rightarrow a\) then,
\[O(f(x))\rightarrow L\]
Kind Regards,
Sudharaka.
I accept the truth of this but I doubt your reasoning because I would have thought you need to conside arbitrary g(x) =O(f(x), not take a particular case (when g(x)=f(x)).
Also, any proof would need to distinguish between strictly big O and 'little' o since it is false in the latter case. For example, x^2= o(1) as x-> 0 but as x->0, x^2->0 while
1-> 1.
Could you explain what $O(f(x))\rightarrow L$ means? When we write $g(x) = O(f(x))$, the right-hand side at worst is simply a part of a notation and at best is a class of functions.
Totally confused this problem thinking that \(O\) represents a function. (Headbang)
1-> 1.
The proof is obviously wrong since \(O\) does not represent a function but a class of functions. Sorry. :)
I mean that the limit of the quotient is a constant
The quotient of what? And how can the limit of a function not be a constant? Are you talking not about the limit of a function but the limit of a sequence of functions?
we say f(x)=O(g(x)) as x-> a if lim{(f(x)/g(x)}= c, where c is not infinity (to answer your second question)
First, this is not the standard definition, which can be found in the link to Wikipedia in post #2. For example, \(\sin(x)=O(1)\) as \(x\to\infty\), but \(\lim_{x\to\infty}\sin(x)/1\) does not exist. Second, this does not answer the question what \(O(f(x))\to L\) means.
I am asking, if F(x) tends to L as x to a, then what does some function that is of order f(x) tend to as x tends to a. As for your claim, I am afraid you are mistaken; sinx=O(1) as x tends to 0, not infinity.
It can tend to any number because "being of order" allows multiplication by any constant factor. For example, if \(f(x)=x\), then \(f(x)\to1\) as \(x\to1\). If \(g(x)=2x\), then \(g(x)=O(f(x))\), but \(g(x)\to2\) as \(x\to1\).
According to the standard definition, it's both.
This thread shows clearly the unormous confusion that Edmund Landau...
Edmund Landau - Wikipedia, the free encyclopedia
... was able to introduce in the wenstern mathematical thought... it is not a surprise that, when the 'cultural authorities' are like Edmund Landau, sooner or later an Adolf Hitler necessarly appears (Wasntme)... Kind regards $\chi$ $\sigma$
I still need to explain the calculation that I have seen that states , for example,
as x->0, lim(O(x^2))=0. Now you can see why I hypothesised as I did. I am grateful for the input exposing my ignorance but for now I just want to focus on the above calculation.
I assume \(O(f(x))\to L\) as \(x\to a\) means that for every function \(g(x)\) such that \(f(x)=O(g(x))\) it is the case that \(g(x)\to L\) as \(x\to a\). Then \(f(x)\to 0\) as \(x\to a\) indeed implies \(O(f(x))\to 0\) as \(x\to a\). This is because for each \(g(x)\in O(f(x))\) there exists a constant \(C\) and a neighborhood of \(a\) where \(|g(x)|\le C|f(x)|\). Since \(f(x)\to 0\), it follows that \(g(x)\to 0\) as well. However, this is true only when the limit of \(f(x)\) is 0.
FAQ: Is There a Connection Between Big 'O' Order Symbols and Limits?
What are Big 'O' order symbols?
Big 'O' order symbols are used in computer science to describe the performance or complexity of an algorithm. They represent the worst-case scenario for the time or space required for an algorithm to run, as the input size increases.
What is the purpose of using Big 'O' order symbols?
The purpose of using Big 'O' order symbols is to analyze and compare the efficiency of different algorithms. By determining the time or space complexity of an algorithm, we can choose the most efficient one for a given problem.
How are Big 'O' order symbols calculated?
Big 'O' order symbols are calculated by examining the number of operations an algorithm performs as the input size increases. The most dominant term is used to represent the complexity, and constants and lower-order terms are ignored.
What is the difference between Big 'O' and Big Omega?
Big 'O' and Big Omega are both used to describe the performance of an algorithm, but they represent different scenarios. Big 'O' represents the upper bound or worst-case scenario, while Big Omega represents the lower bound or best-case scenario for an algorithm's time or space complexity.
Can Big 'O' order symbols be used for all algorithms?
Yes, Big 'O' order symbols can be used for all algorithms, but they are most commonly used for analyzing time complexity. For algorithms that have varying time or space complexity depending on the input, we use Big Theta (Θ) to represent the average-case scenario.
