Is there a critical pressure for melting ice?
In summary, the conversation discusses the relationship between pressure and the phase of water, specifically how at higher pressures, ice is more likely to turn into liquid. The question arises if there is a point where the pressure is so high that water will always remain liquid regardless of temperature, and if this is even theoretically possible. The topic of supercritical fluids is also mentioned, with the possibility of having a supercritical fluid in the solid phase region being questioned.
Conrad S
I know the specific volume for Ice is higher than water so increases in pressure make it more favorable for the ice to go to water (hence a negative slope on a phase diagram rather than positive)
Is there a point at which if the pressure was so high that it would be have to be liquid no matter what the temperature was?
Is this even theoretically possible?
I took your question to be
Conrad S said:
Is there a point at which if the pressure was so high that it would be have to be liquid no matter what the temperature was? Is this even theoretically possible?
High temperature and high pressure make a supercritical fluid, with which i have a bit of experience. I'll have to think about a solid.
so that kind of opens up another question, so a supercritical fluid is when the the temperature and pressure are above the critical point, but at the top right of the phase diagram there is still a region where there are solids. Is is possible to have a supercritical fluid that is in the solid phase region?
or does that solid liquid line curve up really fast?
Related to Is there a critical pressure for melting ice?
1. What is the critical pressure for melting ice?
The critical pressure for melting ice is the pressure at which ice can no longer exist in its solid form and will instead melt into a liquid state.
2. How does pressure affect the melting point of ice?
As pressure increases, the melting point of ice decreases. This is due to the fact that pressure restricts the movement of molecules, making it more difficult for them to form the crystal structure of ice.
3. Is there a specific temperature at which the critical pressure for melting ice occurs?
Yes, the critical pressure for melting ice occurs at 0 degrees Celsius (32 degrees Fahrenheit) at sea level. This is the point at which ice and liquid water can coexist at equilibrium.
4. Can the critical pressure for melting ice vary in different environments?
Yes, the critical pressure for melting ice can vary depending on the environmental conditions. For example, at higher altitudes where the atmospheric pressure is lower, the critical pressure for melting ice will also be lower.
5. How does the critical pressure for melting ice impact the Earth's climate?
The critical pressure for melting ice plays a crucial role in the Earth's climate. As atmospheric pressure changes, it can affect the melting of ice in polar regions, which can lead to changes in sea levels and ocean currents.
